SolaraGuy.com • View topic - oil + supercharger...
Postby SC V6 » Fri May 30, 2003 1:35 pm
I was looking at the back of my SC from the passanger side of the hood... and I noticed that oil was leaking... the bolt next to the pulley, above the bolt used for the ground wires, was only hand tightened.. and oil was leaking... now... how do u get more inside... is it bad to not have that much.... help please
thanks
Scott
SC V6
Postby Mole » Fri May 30, 2003 6:31 pm
if the s/c is fresh, then some leakage can occur. i know one guy that his s/c leaked out all the oil. mine however did not leak any. but it should stop with in a week or so what i have been told.
makes me think that i am empty to start with.
Postby SC V6 » Fri May 30, 2003 7:33 pm
it leaked out the back bolt thing... I tightened it.. and it stopped... I shouldn't worry right?\
thanks
Scott
Also I was talking to some people about it and they said that it should be connected to the main oil supply... is this true or not???
SC V6
thanks
Scott
also.. where was everyone else's leaking?? is that the only bolt connected to the oil?
SC V6
Postby Mole » Sat May 31, 2003 12:45 am
s/c oil is different than engine oil.
perhaps they were talking about turbocharged situations.
Postby CrazyCraig » Sat May 31, 2003 8:44 am
Scottv6 wrote:it leaked out the back bolt thing... I tightened it.. and it stopped... I shouldn't worry right?\
thanks
Scott
Your supercharger is a sealed unit. I would not attempt to open it up to add oil. If you are really concerned, contact TRD.
As for your last question ......... no, your super charger is self contained. There is no external oiling with the TRD system.
CrazyCraig
CrazyCraig
