SolaraGuy.com • View topic - SAFC Airflow Readings
Postby Eye8Pussies » Sat Mar 22, 2008 10:20 am
for those with an safc/neo...
what readings do you get during:
- idle?
- cruising?
- WOT?
I know the numbers will differ, but I'm trying to get a general idea.
my 94 ecu/MAF setup is different from the later years and I think that's why my ecu rejected my tune/safc adjustments.
Postby Akfahad » Sun Mar 23, 2008 3:28 pm
you want to know what the correction % reads at those different throttle positions??
If so, mine are:
Idle: 3.0 - 4.5
Cruising: 4.5 - 5
WOT: 22 - 24
Postby Robert » Sun Mar 23, 2008 4:10 pm
What do you have done to your car akfahad ??
Robert
Postby CamryOnBronze » Sun Mar 23, 2008 4:21 pm
^ click the car domain link in his sig...
Postby Robert » Sun Mar 23, 2008 4:28 pm
CamryOnBronze wrote:^ click the car domain link in his sig...
IC now :)
Robert
Postby Eye8Pussies » Sun Mar 23, 2008 8:56 pm
Akfahad wrote:you want to know what the correction % reads at those different throttle positions??
If so, mine are:
Idle: 3.0 - 4.5
Cruising: 4.5 - 5
WOT: 22 - 24
thanks, but I'm not looking for the adjustment numbers actually. I need the actual MAF readings that the SAFC is getting
Postby trd4life » Thu Mar 27, 2008 5:25 am
well with my 3.3 camry which uses a supra maf and safc i am getting 37.5 airflow at WOT, my soalra was hitting 70% with the supra maf at WOT, and my old camry was hitting 85% at wot on the stock maf. Airflow at idle is always 2%
Postby Eye8Pussies » Thu Mar 27, 2008 10:13 am
thanks gabe, that's what I needed to know!
Postby Dawgz » Fri Mar 28, 2008 2:59 pm
idle: 1-2%
Crusing: 9-15%
@ 84% throttle it was reading 58%
Re: SAFC Airflow Readings
Postby RON » Wed May 27, 2009 12:06 am
Eye8Pussies wrote:for those with an safc/neo...
- idle?
- cruising?
- WOT?
Glad I finally found this post! I recently asked a similar question, but no one is *home*! Don't recall idle exactly, but it's under 5%....cruising is probably 10-20%. However, at WOT (100% throttle reading) I got a snap shot on my SAFC at 71.6% @ 6500 RPM (hit rev limiter cut off!). It really depends on temps, since you're measuring MAF..which depends on DENSITY. The temp was around 73 at the time. I saw someone (TRDFORLIFE) got 85%!!! WOW...I don't think I could ever get it that high..even in COLD air.
RON
Postby trd4life » Wed May 27, 2009 11:29 am
Ron , in case you were wondering. That was with a similar setup to yours but a 7psi and 3" catback exhaust a 3" y pipe w/ no cat.
Postby RON » Wed May 27, 2009 1:07 pm
trd4life wrote:Ron , in case you were wondering. That was with a similar setup to yours but a 7psi and 3" catback exhaust a 3" y pipe w/ no cat.
That 85% is a HUGE # alright. I have 5.5lb with 2 1/2" Y pipe going into CAT and 3"(I think) Greddy Evo going out. I have another cone filter with a front that's OPEN and tappered inward (J&B). I'll put that back in soon. I wonder if air flow will go up with that?
RON
Postby Midias » Wed May 27, 2009 1:43 pm
Unless you have a custom greddy it is about 2.5in maybe a little less I think it is a metric size.
Postby trd4life » Wed May 27, 2009 1:44 pm
my power jumped form 260whp to 274whp with the addition of the 3" catback over the Greddy EVO i had on there at first.
Postby TxBmbleBee » Wed May 27, 2009 5:00 pm
i thought the greddy evo was a 3" catback
"i just wanna go fast..."
TxBmbleBee
