SolaraGuy.com • View topic - 1MZ-FE Twin Plate Clutch?
Postby hksboost » Sat Apr 05, 2008 2:02 am
Can I use a twin plate clutch for 3SGTE Mr2 in to my 1mz-fe camry since they both have the E153 transmission. Because I searched for a twin plate clutch for 1mz-fe but I did not find one. :(
TurboNetics T-60
471 Whp / 467 lbft @ 20 psi
hksboost
clutch
Postby trd4life » Sat Apr 05, 2008 8:01 am
clutch is the same mr2 flywheel has a different bolt pattern
Postby hksboost » Sat Apr 05, 2008 12:39 pm
The problem is that a single plate clutch is no more capable to handle the amount of torque I have so the twin plate clutch is a most to have. What should I do to install the twin plate clutch from 3SGTE Mr2 in to my 1mz camry since the twin plate clutch kit includes the flywheel?
TurboNetics T-60
hksboost
Postby hskrsolara » Sat Apr 05, 2008 5:36 pm
The spec line of clutches can handle massive amounts of power...
hskrsolara
Postby hksboost » Sat Apr 05, 2008 11:02 pm
hskrsolara wrote:The spec line of clutches can handle massive amounts of power...
So you advice me to go with SPEC..
If there is no way to install a twin plate then i will go to the best single plate clutch for 1MZ..
So what is the best single plate clutch for 1MZ?
TurboNetics T-60
hksboost
Postby hskrsolara » Sun Apr 06, 2008 12:03 am
The stage 3 is very popular...I have the spec 2+ with a fidanza flywheel, but you will probably need at least a spec stage 3, maybe even a stage 3+ or 4...but that would severely limit day-to-day drivability.
hskrsolara
Postby hskrsolara » Sun Apr 06, 2008 12:08 am
Here is a handy list of all spec clutches available, sorted by stage. A stage 3+ looks about perfect for ya...
http://www.lmperformance.com/c/2/90.html
hskrsolara
Postby Midias » Sun Apr 06, 2008 6:17 am
hskrsolara wrote:Here is a handy list of all spec clutches available, sorted by stage. A stage 3 or 3+ looks about perfect for ya...
Max tq is 580 I believe this guy is pushing about 500 at the wheels so I am not sure if he rally wants to go that route. But I would call clutch companies they are usually more than willing to beef up a clutch for your application.
Postby hskrsolara » Sun Apr 06, 2008 9:20 am
If he has 500 at the wheels, then a stage 5 would work fine. Unfortunately, they aren't listed on that site.
http://www.horsepowerfreaks.com/price/T ... lutch_Kits
I would give horsepowerfreaks a call. They were very helpful when I bought my 2+ from them and very knowledgeable.
hskrsolara
Postby Midias » Sun Apr 06, 2008 4:58 pm
Looks like spec makes a stage 5 clutch you may be able to use
http://www.horsepowerfreaks.com/price/T ... rt_Stage_5
Postby hksboost » Mon Apr 07, 2008 12:47 am
Thank you guys, as I can see that stage 3+ capacity is 580, stage 4 capacity is 485 and stage 5 capacity is 685.. So stage 3+ and stage 5 are handling very good capacity of torque but I think that I will go with SPEC stage 5 clutch to be in the safe side..
TurboNetics T-60
hksboost
Postby hskrsolara » Mon Apr 07, 2008 5:21 am
Let us know how it drives...very curious how that level of clutch will feel in a camry. Good Luck!
hskrsolara
Postby Eye8Pussies » Mon Apr 07, 2008 11:27 am
I'm pretty happy with my stage3, personally....and the driveability in traffic is a bitch, but do-able
I hate to think how a stage 5 clutch would feel though...lol
Postby QuickSEV6 » Mon Apr 07, 2008 11:51 am
There used to be a guy on SolaraGuy that had Clutchmasters.
http://www.clutchmasters.com/
There is also a mechanic in my area that swears by them.
Stage three will be more than enough to accomodate your torque.
Stage 4 and 5 are designed more for track use and would not provide a comfortable ride.
Postby hksboost » Mon Apr 07, 2008 10:54 pm
QuickSEV6 wrote:There used to be a guy on SolaraGuy that had Clutchmasters.
Man i am using stage 3 and it is not enough at all because of this i will go to stage 5 and then i will rise my boost from 22 psi to 25 psi.. the stage 3 can not handle the 22 psi how in the hell i will go to 25 psi with it
TurboNetics T-60
hksboost
