SolaraGuy.com • View topic - CARBON FIBER GAUGE BEZEL
Postby jello » Mon Jun 02, 2003 11:03 pm
I got a gauge bezel. How do I get to the gauges. I took out the 2 screws at the top what else do I have to do?
00 solara sle
jello
Postby Mole » Mon Jun 02, 2003 11:20 pm
use the search... it has been discussd before..
Postby jello » Mon Jun 02, 2003 11:31 pm
i searched... can you post a link of where it was talked about? Thanks
00 solara sle
jello
Postby Mole » Mon Jun 02, 2003 11:35 pm
ah nm...
after taking the two screws from the top out, you should be able to bend the plastic cover lining of the cluster. once that is out, there are 4 more screws securing the guage cluster housing. once those are removed there will be some plugs at the top. take those out as they are "idiot-proof," time when you put them back in. you will have to find the correct angle to pull the cluster out. not that hard at all. once the cluster is out and disconnected, slowly pry open the platic cover using a smaller standard screwdriver. pry the whole 360 of the cluster. if you get impatient and rip it off by hand, there is a good chance of cracking the cover. once it is open, then lay on the bezel. reinforce with small amts of double sided stick tape. to put it back in, do steps the steps you did to take it out in reverse.
GL
