SolaraGuy.com • View topic - Replacing front sway bar bushings
Postby TMMK Toy » Sun Apr 13, 2008 12:13 am
So I'm gonna order energy bushings for my front antisway bar and they show a listing of either 18 or 19 mm bushing. How do I know what I need? The car is a 99 camry le v6 5 speed if that helps. Rather just order this part once
TMMK Toy
Postby TMMK Toy » Wed Apr 16, 2008 3:55 pm
bump
TMMK Toy
Postby mazen222 » Sun Feb 28, 2010 4:26 pm
ya i have the same question... anyone knows? i have 1999 std v6
Fitment: 1995-2003 Toyota Avalon, 1997-2001 Camry, 1999-2003 Solara
Part # (Note: For product color add R for red or G for black after each part number)
Let us know what diameter your away bar is so we send the correct bushings to you.
19mm uses 9.5123
18mm uses 9.5122
there's also another website calling for 16 mm dia... ?? how can i know without actually measuring it?
1999, 5 Speed V6
mazen222
Postby 99BlackSandv6 » Sun Feb 28, 2010 4:30 pm
Grab your open end wrenches and see which one fits around the bar.
Postby chullen1 » Sun Feb 28, 2010 6:26 pm
I bought the 19mm ones and they seem to work fine. I have a 1999 Camry LE V6 5spd also.
chullen1
Postby mazen222 » Sun Feb 28, 2010 8:23 pm
chullen1 wrote:I bought the 19mm ones and they seem to work fine. I have a 1999 Camry LE V6 5spd also.
thanks,
can anyone confirm the same for CND made model? there are some small differences with the usa
1999, 5 Speed V6
mazen222
Postby 99BlackSandv6 » Sun Feb 28, 2010 8:23 pm
They're the same.
Postby SleeperSolara » Mon Mar 01, 2010 11:15 am
I think the OEM front sway bar is 18mm??
From what i can remember.....
Last edited by SleeperSolara on Mon Mar 01, 2010 11:18 am, edited 1 time in total.
Postby 99BlackSandv6 » Mon Mar 01, 2010 11:18 am
^I was also thinking it was 18. I know I checked back when I upgraded to the TRD RSB.
I'll check again in a little while. It only takes a second.
Postby trd4life » Tue Mar 02, 2010 12:32 am
crap man i thinks its 16 or 17mm on my 97 camry front sway
Postby SleeperSolara » Tue Mar 02, 2010 11:59 am
99BlackSandv6 wrote:^I was also thinking it was 18. I know I checked back when I upgraded to the TRD RSB.
Yeah i think it's 18mm for the front, cause i changed my OEM front sway bar to Whiteline.
