SolaraGuy.com • View topic - TRD Thermostat
TRD Thermostat
TRD Thermostat
Postby facevedo17 » Wed Apr 16, 2008 8:21 am
Hello guys were can I find the TRD thermostat for our cars ...are the ones they make for the Tacomas and supras fit our cars ? I need these Asap ...and the only one I found online was carsons toyota but they take to long to deliver ..6 to 8 weeks I need this by next week the latest can someone help.....
facevedo17
Postby facevedo17 » Wed Apr 16, 2008 8:56 am
I found a post here on the forum that a celica thermostat can fit has anyone gone that route, and then there is stant as well but they are 170 ' Trd is 160 '
facevedo17
Postby facevedo17 » Wed Apr 16, 2008 9:21 am
has anyone bought from this place before
http://www.brandsport.com/160dethbbyto.html
they state thermostat Part number is PTR04-00009 wich is the same as the celica 00-03 versions I wonder if the gaskets are different ...they should be the same as oem right guys ???
facevedo17
Postby QuickSEV6 » Wed Apr 16, 2008 9:22 am
Sorry. I can't help.
I got mine from a website in New Zealand. They no longer sell parts to the US.
I checked every other toyota site I know of. No luck. Sorry.
I wish you luck in your quest.
Postby Eye8Pussies » Wed Apr 16, 2008 9:37 am
why do you need one in such a rush? it takes about 5 min to change it?
also, the 170 will generally be more than enough, so that shouldn't be too big of a worry
as for the celica ones, one way to find out is to go to napa and take a look at the camry one and the celica one and then compare them to see if they are the same size- the gasket is usually purchased separately anyway
Postby facevedo17 » Wed Apr 16, 2008 9:49 am
well I have all my parts ready gaskets I needed Im starting to worked on the solara next week . just got a new tranny put in the cabrio so it delay me a bit ...My engine tempeture guage is a little over the middle wich most cars are usually at ....its halfway between the middle and getting to the hotzone ...something I want to take care of before adding the SC ...I have a new water pump , timing belt in there so that leaves me with replacing the thermostat....hopefully that would bring it back to the middle ...
facevedo17
Postby Midias » Wed Apr 16, 2008 10:08 am
I think one of them will work here is a list I made for shocar when I cross referenced the part number for the 170 degree stant stat.
http://www.solaraguy.com/viewtopic.php?p=443580#443580
Postby facevedo17 » Wed Apr 16, 2008 11:23 am
I was looking into those can I get them from Napa or an autozone ?do you know or I have to go thru their website ?
facevedo17
Postby Midias » Wed Apr 16, 2008 11:29 am
facevedo17 wrote:I was looking into those can I get them from Napa or an autozone ?do you know or I have to go thru their website ?
Advance auto parts carries the stant 170 thermostat. But I would be willing to bet if you gave the part number to nappa or autozone they could cross reference it with one of there own.
Postby TMMK Toy » Wed Apr 16, 2008 3:49 pm
check ur coolant system out first (pressure test) to make sure it is just the thermostate causing u to overheat and nothing something else
TMMK Toy
Postby CASTRO » Wed Apr 16, 2008 10:09 pm
ive got the same one quick has prolly the same place too. 160* TRD ftw!
CASTRO
Postby QuickSEV6 » Wed Apr 16, 2008 10:10 pm
CASTRO wrote:ive got the same one quick has prolly the same place too. 160* TRD ftw!
Yup. Actually, I started a tread asking where to find it and you posted it for me. We have the same one.
Postby CASTRO » Wed Apr 16, 2008 10:55 pm
damn was it that long ago? haha i allready forgot.
TRD 160* FTW! accept no other
CASTRO
Postby facevedo17 » Fri Apr 18, 2008 5:36 pm
well guys I order my Thermostat today from this site greg had on his page I order the Camry one because it was a lil cheaper than the solara comes with 3 gaskets and all If they come in by thursday I guess i could wait ..
facevedo17
Postby lexmex » Sat Apr 19, 2008 7:18 am
lexmex
