SolaraGuy.com • View topic - Electrical hookup for aftermarket spoiler third brake light
Postby jwhite5 » Wed Jun 04, 2003 7:25 am
:x I installed an aftermarket spoiler, it has two wires for light hookup, there is a connector in the left side going to the tail lights, I tried hooking to this connector and blew a fuse... Where and how do I connect this light?
2000 Solara SE
jwhite5
Postby krook » Wed Jun 04, 2003 2:34 pm
use a multimeter or test light to probe which a wire in the harnesses running to your oem brake lights. hook one of those wires FROM THE SPOILER to ground, and hook up the other wire with a fuse to the wire you believe to be the correct brake wire you previously tested.
krook
Postby Guest » Wed Jun 04, 2003 3:10 pm
Pull out the driverside trunk interior, you will see a extra wire with connectors. That's where you suppose to hook up.
Guest
Postby Turbosolara » Thu Jun 05, 2003 11:29 pm
it was me, forgot to log in
