SolaraGuy.com • View topic - Help me pls!! rotor install
Postby s15lara » Sun Apr 20, 2008 7:25 pm
so i bought slotted and cross drilled rotors from R1concepts and am in the process of installing them right now. now i know how to change pads and rotors but im REALLY stumped right now. I have no idea which rotor goes on the left and which goes on the right. The box came with no instructions and i checked the rotors and there are no markings that let me know which side is which. can anyone help? pls? i'd greatly appreciate it.
here is a pic.
top are rear rotors and bottom are front rotors. but which go to the left and which go to the right? pls help....
http://www.cardomain.com/ride/799836/5
last pic btw. thnx guys...
almost there...what do you think?
s15lara
Postby CamryOnBronze » Sun Apr 20, 2008 7:28 pm
top left= drivers rear
bottom left= driver's front
pretty sure thats right...
Postby krawzyazn » Sun Apr 20, 2008 7:32 pm
I thought the right was drivers side
Postby woa_its_j3ff » Sun Apr 20, 2008 7:36 pm
No I think it's
bottom right is drivers front
then top right is driver rear.
bottom left is passenger front
and top left is passenger rear
Postby s15lara » Sun Apr 20, 2008 7:41 pm
ok...now i'm really confused. anyone else? pls?
s15lara
Postby woa_its_j3ff » Sun Apr 20, 2008 7:43 pm
seriosuly. the direction of the slots are the way how it goes. come down wednesday for the damn photoshoot and i'll help you install it.
Postby s15lara » Sun Apr 20, 2008 8:18 pm
just to confirm....left side is passenger side are the rotors on the left and the drivers side are the rotors on the right? anyone else want to chime in on this???
s15lara
Postby CamryOnBronze » Sun Apr 20, 2008 8:23 pm
i win. :lol:
Postby DatSRBoi » Sun Apr 20, 2008 9:26 pm
I am Dat and I approve of this message
Postby Chinky420 » Sun Apr 20, 2008 11:50 pm
^x2 this is right
Chinky420
Postby Sebas007 » Mon Apr 21, 2008 4:18 am
You had a good nswer on the last post (Down2Thec)
http://www.solaraguy.com/viewtopic.php?t=39249&start=60
Check if the vains are curvy or not....if they are straight then it doesn't matters.
Postby CamryOnBronze » Mon Apr 21, 2008 8:40 am
This is what I was basing my knowledge off of- brembos are vained this direction, so thats the way they are installed:
Postby Mole » Mon Apr 21, 2008 8:45 am
you need to find out who they're made by... power slots are installed going the opposite way of brembos.
in other words, if you look at the slots from the side, it slants towards the back.
Postby s15lara » Mon Apr 21, 2008 3:20 pm
I bought the rotors from R1 concepts. The veins are not diagonal. They just go straight down. so i guess that it doesnt matter? When i look at the rotors from a top view, the veins are going straight down and when i look at it from the back of the rotor, its the same thing. so i guess they are not derectionally veined.
s15lara
Postby s15lara » Mon Apr 21, 2008 3:50 pm
OK. just got off the phone with R1 and they said that since the rotors are NOT directional, that it really makes no diffrence. what they did say is that they found that its better if the slot or cross drilled part closest to the hub come in contact w/ the rotor first. So....for example: if you put the rotor in front of you w/ the slot at the 12 o clock and you look at it, if the slot is slanting to your left, then that is your driver side. soooo....hmmmm....I trust dats and camryonbronze, so i guess that i might just go w/ their advice. thx guys. anyone else have any input?
s15lara
