SolaraGuy.com • View topic - greddy sandwich adapter?
Postby shocar4 » Thu Apr 24, 2008 7:26 pm
i ordered one from a guy on ebay and i received it today and it only came with one o ring on the engine side of the adapter (suppose to be two there) even though the auction said that there was two! any ideas where i can get an o ring that is that size??? thanks
shocar4
Postby Eye8Pussies » Thu Apr 24, 2008 7:27 pm
you can check napa or pepboys...
but why do you need 2 o-rings? you need one on the side of the engine...but you don't need one for the outside, since the oil filter has one right on it....
Postby CamryOnBronze » Thu Apr 24, 2008 7:30 pm
haha, I have the exact same problem... do you mean there is only one o-ring on the side with two slots? thats what mine is like too. Ill let you know if I find the seal somewhere, ill be installing it next week.
Postby shocar4 » Thu Apr 24, 2008 7:51 pm
yeah damon that is exactly what i am talking about! i looked at other auctions also and they all have two also!
shocar4
Postby CamryOnBronze » Thu Apr 24, 2008 8:37 pm
I bet it would seal with just the inside one... if not, I bet permatex would work too...
Postby shocar4 » Fri Apr 25, 2008 7:25 am
yeah i am just nervous that i would do the install and then put my $33 synthetic oil in and have a leak and have to drain it all out! i emailed the seller and he said that he found the o ring and will send it too me....we'll just see if that happens or not!
shocar4
Postby Eye8Pussies » Fri Apr 25, 2008 8:38 am
ah, after taking a look at the greddy design, now I know what you're talking about....
and all you need is one of the o-rings still, but it'll depend on which one they gave you....if you got the one that fits the 1mz, then you're fine...if you didn't and need hte other size, then hopefully the seller sends it to you...
Postby shocar4 » Fri Apr 25, 2008 8:40 am
yeah i have the smaller of the two o rings or the inner one on the adapter.....it looks like it would be best if both o rings are on there!
shocar4
