SolaraGuy.com • View topic - Tokico Struts for solara 02
Postby cruze105 » Thu Jun 05, 2003 12:12 pm
i went to the auto shop to get tokico struts for my solara 2002, but they looked up in the catalog they had and said that they make it only up to the solara 2001. IS the suspension the same for the solara 2002. I checked wit the toyota dealership , they said it was the same , but they said to double check wit the manufature of the tokico struts. doES ANY ONE KNOW IF IT WILL DEFINANTLY FIT THE 2002 VERSION. JUST WANT TO DOUBLE CHECK
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby DavPak » Thu Jun 05, 2003 12:15 pm
it will definitely fit. i have them on my 2002 solara.
'02 Solara S/C'ed V6 5-spd
DavPak
Re: Tokico Struts for solara 02
Postby Flipside909 » Thu Jun 05, 2003 12:32 pm
cruze105 wrote:i went to the auto shop to get tokico struts for my solara 2002, but they looked up in the catalog they had and said that they make it only up to the solara 2001. IS the suspension the same for the solara 2002. I checked wit the toyota dealership , they said it was the same , but they said to double check wit the manufature of the tokico struts. doES ANY ONE KNOW IF IT WILL DEFINANTLY FIT THE 2002 VERSION. JUST WANT TO DOUBLE CHECK
It will fit. Take our word for it!
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby cruze105 » Thu Jun 05, 2003 1:09 pm
ok thanks guyz. one more question will i need a wheel alignment after i get my struts and springs installed?
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby DavPak » Thu Jun 05, 2003 1:18 pm
need it? no
will you want it? yes
DavPak
Postby TXSolaraSLE » Thu Jun 05, 2003 2:42 pm
Well, its always recommended to get your alignment done after suspension changes, so its probably a good idea. Plus, poor alignment settings can make a big difference. I just had my car aligned because I was getting a lot of road noise..now the noise is almost completely gone and the suspension works much smoother. I swore they must've reduced my tire pressure at the dealership, because the ride was so much smoother and quieter. The Toyota dealership charged $65. Definitely money well spent.
Brian
'99 Black Solara SLE
18" Mille Miglia Evo5
Yokohama AVS ES100
Indiglo Gauges
Kicker KSR100
K&N Filter
Xenon Headlights & License plate bulbs
TXSolaraSLE
Postby 99solarai4 » Thu Jun 05, 2003 7:36 pm
It is a really good idea to get it aligned because lowering it will change the camber and toe both front and rear. I installed adjustment cams to make changing the camber easier on mine.
'99 Solara SE i-4
Back to Stock
99solarai4
