SolaraGuy.com • View topic - custom y-pipe???
custom y-pipe???
custom y-pipe???
Postby shocar4 » Mon Apr 28, 2008 12:01 pm
i am getting ready to have a custom y-pipe made at my local shop with no cats at all and my recently purchased o2 sim....my ? is what size pipe should i run from my stock fed headers (manifold) 2.75 or 3 inch?
shocar4
Postby Eye8Pussies » Mon Apr 28, 2008 12:04 pm
ummm....you don't run the actual y-pipe 3" or anything that big....it should go into a collector and then to 3" piping...
usually, the piping itself should be about the same size as the headers. otherwise, say, if you use 3" piping on each downside of the y-pipe, you'll need a huge collector- like a 5" collector or something to prevent turbulence...
one of the biggest weaknesses of the stock y-pipe is the fact that there's a crimp in it for some reason, and the piping is flat in spots as well.
also, since you're paying good money for a y-pipe, make sure that they make the runners as even lengths as possible. The lazy way is to make them uneven, and it's easier/cheaper, but the performance gain is not the same.
Postby PXLpainter » Mon Apr 28, 2008 12:07 pm
Get the Y-pipe that JPP makes! Why reinvent the wheel?
Postby shocar4 » Mon Apr 28, 2008 12:59 pm
so i should just keep the same diameter piping that the oem y-pipe is but minus the crappy design ......jpp is way to much $ for me...when i have a shop here in town that will make whatever i want for a fraction of the cost!
shocar4
Postby M_ABILLONES » Mon Apr 28, 2008 1:52 pm
what's the website for jpp?
M_ABILLONES
Postby SdeA » Mon Apr 28, 2008 1:54 pm
SdeA
Postby Mr_Chunkz » Mon Apr 28, 2008 4:08 pm
jpp header + y pipe FTW
sounds so mean
it growls
i will make a video clip soon so you guys can hear the wonderfulness
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby M_ABILLONES » Mon Apr 28, 2008 8:59 pm
do they make a catless version of these header/y-pipes?
M_ABILLONES
Postby CamryOnBronze » Mon Apr 28, 2008 9:11 pm
^ you could have jose make it without the cat Im sure...
Postby JavaJoe_2 » Mon Apr 28, 2008 9:16 pm
It's a VERY highflow cat.
Got Boost?? :sweet:
JavaJoe_2
Postby Mr_Chunkz » Mon Apr 28, 2008 11:49 pm
since these pieces are made to order im sure jpp would have no problem making a cat delete for you...
however
gettin a hold of them is a whole nother issue
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby M_ABILLONES » Tue Apr 29, 2008 6:04 am
suprisingly they responded within 24 hours when i emailed them? who's jose?
M_ABILLONES
Postby shocar4 » Tue Apr 29, 2008 6:30 am
thanks for the thread jacking guys!
shocar4
Postby CamryOnBronze » Tue Apr 29, 2008 8:16 am
M_ABILONES, PM me if you need more info. Lets keep this on topic for Randy.
Im not sure of the diameter pipe JP uses on their y-pipe randy, I could try to measure for you if I get a chance. Are you planning to do a 3" catback as well?
Postby shocar4 » Tue Apr 29, 2008 8:20 am
thanks damon...not sure just trying to decide what i want to do...measure that for me if you get a chance!
shocar4
Users browsing this forum: Google [Bot] and 28 guests
