SolaraGuy.com • View topic - Custom made spacers
Custom made spacers
Custom made spacers
Postby tweazy » Fri May 09, 2008 8:33 am
So here I am again on my quest to find a 1/2 inch hubcentric spacer and I run into this site that makes custom spacers. I am about to submit my order but I need some input from you guys.
Here is what I want (this is only going to the rear wheel):
1/2" spacer
60.1 hub (bore)
5x114.3 bolt pattern
60.1 wheelcentric lip (this is where the wheels will rest on)
My dilemma is that I am not sure if I want the wheelcentric lip to be 60.1. The wheel's centerbore is 73.1 so... should I just change it to that so that I dont need to use hub centric rings on the spacer?
tweazy
Postby ---CAMRAZY--- » Fri May 09, 2008 9:20 am
If .5 inches are 12.700 mm, then why not just get 10 or 15 mm spacers an call it a day.
I wa running a 15 mm on my old solara and my camrys with a 8.5 width wheel and a +40 offset to begin with.
Postby unbalancedwood » Fri May 09, 2008 10:13 am
Im in the middle of needing/wanting spacers.
My new wheels dont touch the strut, but im just a little worried. I have about 10-15mm max that i could push out my wheels, and about 10-15mm before i touch the strut. Im just a little woried and caucious to actually drive without spacers....what do you think? Milt?
PS, i do not know the offset of my rims
But tires are currently 215/5017 (that i tested with) but i want to purchase 45 series tires...
unbalancedwood
Postby ThatVietGuy » Fri May 09, 2008 10:55 am
^ If you have that much clearance, spacers are unnecessary
ThatVietGuy
Postby tweazy » Fri May 09, 2008 11:08 am
---CAMRAZY--- wrote:If .5 inches are 12.700 mm, then why not just get 10 or 15 mm spacers an call it a day.
I actually have the H&R 15mm hubcentric spacer but it is about 2mm too wide. my offset is +38 and it looks too flushed to the fender and I'll have to shave just about the entire fender (inner) to prevent rubbing.
10mm is too close to my coilovers. right now, my 8.5" wide rims are about 1/4" away from the coilovers.
I tested a 1/2" spacer and it gave the best fitment. but my current spacer is not hubcentric and theres too much wobble/vibration. what makes the wobble worse is that the wheels use extended thread lugs.
tweazy
Postby tweazy » Fri May 09, 2008 11:13 am
Here is the website by the way:
www.skulte.com
they specialize in Domestics (american) cars.
tweazy
Postby redgen1 » Fri May 09, 2008 2:54 pm
i have a set of 15mm H&R spacers that i happen to have left over after my first attempt at new rims haha, NIB, shipped for 100 even.. they've been in my closet for a year and i need cash bad.. PM if youre interested..
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby ptballer » Fri May 09, 2008 3:24 pm
redgen1 wrote:i have a set of 15mm H&R spacers that i happen to have left over after my first attempt at new rims haha, NIB, shipped for 100 even.. they've been in my closet for a year and i need cash bad.. PM if youre interested..
Do the spacers have the built in studs?
ptballer
Postby redgen1 » Fri May 09, 2008 3:35 pm
nah, but they do come with them - you have to remove the hub to install the longer studs.
02 SLE V6
redgen1
Postby Toy1mzfe » Fri May 09, 2008 4:08 pm
Shave the fenders and drop bigger spacers. it will make your car look hot.
My +35 in the rear needed the fender line shaved. And i still have about.. maybe 3-4 mm between rim and strut. lets say i cant put my index finger thru.
Postby akora12 » Fri May 09, 2008 4:23 pm
Toy1mzfe wrote:Shave the fenders and drop bigger spacers. it will make your car look hot.
Same here...I can't even fit a finger in between my strut and wheel, but it works.
Postby redgen1 » Fri May 09, 2008 5:23 pm
ditto.
02 SLE V6
redgen1
Postby tweazy » Sun May 11, 2008 3:25 pm
Have you guys run into problem with the strut being too close to the wheel? I'm a little worried that it's that close.
I haven't driven my car past 75mph since I had my 19" rims. I've been very careful.
tweazy
