SolaraGuy.com • View topic - accord lipkit
accord lipkit
accord lipkit
Postby talaznfoo » Mon Jun 09, 2003 12:41 pm
since accord and solara have similar dimensions, is it possible to put a lip kit for a 1998-2002 honda accord on a solara?
if yes, then around how much will it take to like mold/put it on?
trd lip kit is a lil too expensive..... :o
also, will the cattback (dual exhaust) system make my V4 solara lag or slow down?
thanx in advance...
www.cardomain.com/id/talaznfoo
2001 Solara SE, silver, 7 piece TRD kit, 19 Axis TC-Evolution, Eibach Pro Kit, Tokico shocks,reverse gaugages, euro corners
talaznfoo
Postby Jackass-Jeff » Mon Jun 09, 2003 1:41 pm
They are totally different shapes. The lip kits are usually bolt ons, so there are spots for you to attach it to the existing facade. Since a Solara is NOT an Accord, it will not fit. (But if you have the money... you can get a shop, like VIS, close to us, and have them make one for the Solara... but they probably won't due to lack of demand)
The catback will always help, but not a noticable difference unless you are running forced induction.
Note: Solaras are avail. with i4 and v6 engines ONLY. There is no "V4" Solara.
Uh ohz! Did I sound like Ryan? **YIKES**
1GR-FE ftw!
Jackass-Jeff
Postby Mole » Mon Jun 09, 2003 3:02 pm
lol....
dude- tall guy... you want to be named Hybrid Ricer ?? well to each their own, but i gave my .02
about the exhaust system. depending on what you will get it will either do some good, nothing, or actually make performance worse. you know you will be set if you get an exhaust system if it was made for your platform, but if you were to get some custom stuff done, make sure you get the correct dimensions, like pipping size. going dual will probably do nothing as a single pipe can achieve, so it would be just for show.
