SolaraGuy.com • View topic - Any advice before install???
Postby M_ABILLONES » Thu May 29, 2008 6:25 am
Guys,
I just bought a set of "staggered" wheels for my Gen 1.5 Solara. But before I install the wheels I wanted to see if you guys can give me some advice on preventing tire rub, wheel spacers needed, extending lug, etc.
Here are the specs:
19x8.50/+32 Offset in the back
18x8.50/+35 Offset in the front
Was lowered using Tein-Tokico combo but now I have the new K-Sport Coilover kit.
Thanks,
Mark
M_ABILLONES
Postby CamryOnBronze » Thu May 29, 2008 6:26 am
32 offset is pretty aggressive for the rear I think- you for sure wont need any spacers front or rear, the front should be perfect. The rear is probably about at the lowest offset you can possibly run, so youre really gonna need to roll those bad boys... if not shave or pull them/
Postby M_ABILLONES » Thu May 29, 2008 6:54 am
the rear is already rolled...aggressively rolled too...
M_ABILLONES
Postby woa_its_j3ff » Thu May 29, 2008 7:02 am
M_ABILLONES wrote:the rear is already rolled...aggressively rolled too...
you should be good to go with that setup man. post up some pics once you get them on!
Postby Midias » Thu May 29, 2008 7:23 am
For spacers get the ones with a built in hub lip
Postby woa_its_j3ff » Thu May 29, 2008 7:27 am
Midias wrote:For spacers get the ones with a built in hub lip
oh and to add on to that, if you're wondering, the hub size is 60.1
H&R spacers I believe have a hub ring,
The Kic's spacers do not.
Postby Midias » Thu May 29, 2008 7:29 am
Some H&R do if I remember correctly their 5mm do not they just have the stock hub sticking out but I personally do not think it sticks out far enough for proper balance.
I am currently running 20mm because they had the hub and I got a good deal on them no problems.
Postby M_ABILLONES » Thu May 29, 2008 7:30 am
Well how do I know if I need spacer(s) to the rear? At that, what size should I buy?
Mark
M_ABILLONES
Postby M_ABILLONES » Thu May 29, 2008 7:32 am
So correct me if I'm wrong but the spacer is used to "push out" the wheels to prevent rubbing? In that case should I also replace the lug stem with an extended one?
M_ABILLONES
Postby Midias » Thu May 29, 2008 7:33 am
I am not knowledgeable of rim sizes to tell you off the bad but if you put the tire on and it rubs on the strut it is time for spacers. I personally like the thicker kind that bolt on so you do not have to replace wheel studs.
Like this one
Postby M_ABILLONES » Thu May 29, 2008 7:38 am
Oh I like that one with the studs already! That's the brand TC Sportsline? That's it for me!!!
M_ABILLONES
Postby Midias » Thu May 29, 2008 7:41 am
M_ABILLONES wrote:Oh I like that one with the studs already! That's the brand TC Sportsline? That's it for me!!!
Actually that was just a picture I pulled off ebay searching for "solara wheel spacer" I actually own THIS SPACER and the quality is very nice and the fitment with the hub is super close tolerance plus they got them to me in about 2 days. If you want I can pop the wheel off when I get home and take a picture of them.
Don't let their feedback fool you ebay recently changed how they do feed back to include neutrals and only go back 12 months. So everyones score went down.
Postby woa_its_j3ff » Thu May 29, 2008 7:45 am
Another thing about spacers.
Make sure you get ones with the 12x1.5 thread, not the 12x1.25 thread, otherwise you're fu*ked. :)
Postby Sebas007 » Thu May 29, 2008 8:06 am
Don't need any spacers...your wheels will be already pretty much pushed outside of your car maybe even too much! You'll need to play with the camber I guess ! Really agressive choice but if you make it fit right...it will look really nice, no matter your wheel style.
Postby CamryOnBronze » Thu May 29, 2008 11:32 am
+1 he has no need for spacers guys... those offsets are already very very aggressive.
