SolaraGuy.com • View topic - TEIN COIL HELP
TEIN COIL HELP
TEIN COIL HELP
Postby AllShowNoGo » Wed Jun 11, 2008 5:21 pm
Just installed the tein coilovers with trd RSB, all bushings and sway bar links and strut mounts and i noticed something odd. The coilvers state 16 levels of dampering yet i hear 26 ticks when i adjust them..
Any of you who have these i would love to here your input..
Also i didnt over torch them i adjusted them before putting them on the car..
AllShowNoGo
Postby Akfahad » Wed Jun 11, 2008 7:05 pm
hmmm...seems like I have 28 clicks starting from the extreme right (the stiffest setting). Not exactly sure, but maybe every 2 clicks equates to 1 level of dampening.
Postby AllShowNoGo » Wed Jun 11, 2008 8:25 pm
what do you have yours set at? How many clicks back from the hardest setting
AllShowNoGo
Postby xan16 » Wed Jun 11, 2008 8:40 pm
If it is anything like the JIC system, you can read this:
JIC Dampening Adjustment
It says theres 15 clicks and anything lower than that simply doesn't do anything.
2000 Solara SE V6. Autumn Red Mica
[ Eibach lowering springs | Tokico struts | 17x8 wheels | custom exhaust | tint | etc... ]
xan16
Postby Akfahad » Thu Jun 12, 2008 6:32 am
AllShowNoGo wrote:what do you have yours set at? How many clicks back from the hardest setting
I have both the front and the rear set on the hardest setting. I believe the instructions say to go all the way soft (left turn) and then back it off 10 clicks for the neutral setting. Double check the instructions if that's what you want.
Postby AllShowNoGo » Thu Jun 12, 2008 6:41 am
Thanks for help guys...
Its funny i thought the tein coilover setup was going to be similar to the tein tokico combo. Not even close!!!! These baby's handle...
Also thought i let u guys know i picked up moog sway bar links.. All i have to say is WOW, twice the size of oem plus they come with Grease Nipples.
AllShowNoGo
Postby Akfahad » Thu Jun 12, 2008 9:19 am
^^hell yeah, I replaced my rear sway bar end links when I did mine, a LOT bigger than OEM.
Postby 1st Gen Sol » Fri Jun 13, 2008 2:35 pm
I need to pick up a set of new sway bar end links, you have the website to where you guys purchased a set from ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Akfahad » Fri Jun 13, 2008 3:51 pm
^^just went to my local autozone. they'll probably have to order them.
Postby 1st Gen Sol » Fri Jun 13, 2008 4:13 pm
Coo, thanks for the info.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby ptballer » Sat Jun 14, 2008 7:47 pm
1st Gen Sol wrote:I need to pick up a set of new sway bar end links, you have the website to where you guys purchased a set from ?
You can go to Arch Auto in queens thats where I got mine from.
ptballer
Postby AllShowNoGo » Sun Jun 15, 2008 7:45 am
http://www2.partstrain.com/store/?N=117 ... 67025+5893
Moog aint cheap but the stuff is the real deal....
AllShowNoGo
Postby 1st Gen Sol » Sun Jun 15, 2008 9:11 am
^^^^ Thanks for the links guys, gonna pick me up a set once I get the chance.
1st Gen Sol
Stock Sleeper
Stock Sleeper
