SolaraGuy.com • View topic - Fuel Pump for the bigger pulleys
Postby SC V6 » Fri Jun 13, 2003 11:12 am
Where have people been getting there new fuel pumps and other fuel items for the larger PSI pulleys? Im looking into running a lot more boost... thanks
Scott
SC V6
Postby Mole » Fri Jun 13, 2003 11:33 am
just a reminder, fuel is not the only problem dude...
internals (cylinder heads, pistons, rods) is the key to have a motor that can handle high boost.
but what i hear is that our fuel pumps are still good enough, it is the injectors that is the bottleneck. i think SC300 or non-turbo supra fuel injectors are drop in replacements. as for fuel pumps, not too sure, but "Walbro"?? not too sure on that...
Postby SC V6 » Fri Jun 13, 2003 11:46 am
yeah im looking into new pistons, the low compression ones... and I know that the fuel will be a problem... im just looking into it so I have the information that I need to know... thanks
Scott
SC V6
Postby Yanks0114 » Fri Jun 13, 2003 12:10 pm
any of the injectors from the NA 2jz will work fine.
Postby chef solara » Fri Jun 13, 2003 1:04 pm
I hava a upgrade fuel pump, I bought it from EL. Prototypes, in CA.
After I changed my pulley to a 6PSI, my car was running rich with stock setting on my S-AFC. So all I had to do was lean it out a bit, but I still managed to set off the knock censer. Well I shouldn't say that because I still dont know what's exactly wrong with it. I hear this tinny noise sometimes at high RPM's
Well back to the fuel pump, I paid alot. It was like 400.dollar w/ a 100 core charge. But it just dropped right in, no problem at all.
The problem that I also thought of was, if I want to sell the car without any upgrades I have to buy a stock fuel pump, since I mailed mine back to EL. for the core charge refund.
chef solara
Postby JoeB » Thu Aug 21, 2003 6:22 am
So does anybody know if an upgraded fuel pump and injectors are necessary for sure? OK, silly question and will definitly vary with which mods are done to the car. See my mods below. I'm getting ready to put the 6psi pulley and S-AFCii on and have it dyno tuned. I'm wondering if I should expect fuel delivery problems and should consider the injectors and/or fuel pump before I go there... OR, at 6psi with modified intake and 3" exhaust am I ok with stock fp and injectors? Thanks -JoeB
Red '99 Solara SLE (V6 AT)
(TRD Stage 3 Performance kit)
TRD Body kit, springs, struts, wheels
TRD front & rear sway bars
TRD Super Charger
TRD Exhaust (JPP Exhaust soon!)
JP Performance Headers and Y-Pipe
RMM Intake Kit
6 PSI pulley (next week)
Apexi SAFCii Limited Edition (next week)
Clear corners
PIAA H4 Super Plasma GT-X H4 60/55w=135/125w headlights
35% Window tint (legal restriction in MD)
Stripped all badging
Xerd CAI if I'm convinced of the solution.
Open to suggestions too :wink:
JoeB
Postby chef solara » Thu Aug 21, 2003 7:06 am
Well joe, I didn't have anyother problems w/ fuel after I installed my new pump.
The problem that I ran into is that w/ the 6psi pulley I craked a piston, Allthough I dont have the header yet. but the car eats gas, for me it's like 10 dollars every 2 to 3 days.
chef solara
Postby Mole » Thu Aug 21, 2003 9:23 am
geezes... you haver to fill up every 2-3 days? where do you drive to?!
if you dont drive that far, then stop flooring your poor baby
Users browsing this forum: Google [Bot] and 45 guests
