SolaraGuy.com • View topic - Where do u put those hid ballasts?
Postby mazen222 » Mon Jul 28, 2008 3:58 pm
i just received my hids... those ballast are huge... i can see where i can install the passanger side one, but where do u guys install the driver side one?
I tried searching but i didnt find any
thanks
mazen222
Postby SleeperSolara » Mon Jul 28, 2008 4:35 pm
Take the plastic snorkel for the intake [sits behind the fuse box].
You will have to take the battery out and un bolt the fuse box out and then you can access the OEM snorkel, and then you can mount the ballast on the driver side there.
Postby Camry Racing » Mon Jul 28, 2008 5:23 pm
shoulb be easy I got 4 ballast installed
and becareful with the driver side one to not put it to close of the intake manifold cause the heat from there fry one of my ballast once
Camry Racing
Postby r0w » Mon Jul 28, 2008 5:47 pm
i put mine under my headlamp assem. there is a nice little section there for it to screw into the frame :D
r0w
Postby M_ABILLONES » Mon Jul 28, 2008 5:54 pm
I installed mine behind the front bumper
M_ABILLONES
Postby NeFaRiOuS_SLE » Mon Jul 28, 2008 10:21 pm
Mine... I went for a stealth set-up that took me nearly an hour on each side to perfect.
For the left side, I found a couple of unused holes that matched up perfectly with the ballast's holes under the fuse box.
For the right side, I zip-tied the bottom of the ballast to the windshield washer fluid reservoir and bolted it to the top.
Postby ThatVietGuy » Mon Jul 28, 2008 10:47 pm
Under the battery, there's a nice little "shelf" to place it.
ThatVietGuy
Users browsing this forum: Google [Bot] and 100 guests
