SolaraGuy.com • View topic - URD o2 simulator
URD o2 simulator
URD o2 simulator
Postby cartang » Thu Jul 31, 2008 12:03 pm
Hi : I have camry SC , without catalitic converter , I want to buy the URD simulator , I search on the URD Web , any advice which one to buy ( prices from 69-to 89 ) any model or kind for camry/ Solara Thanks in advance
cartang
Postby Akfahad » Thu Jul 31, 2008 12:19 pm
this is the one I got:
http://www.urdusa.com/product_info.php?products_id=1230100014
just tap it into the ECU...you'll have to search for which wires to splice, I can't remember anymore.
Postby Dawgz » Thu Jul 31, 2008 12:59 pm
well, there are two types, Type A which is for Federal Spec Solaras, and then Type B for Cali Spec Solaras.
Postby cartang » Thu Jul 31, 2008 1:18 pm
Thanks , are you in California? beacuse the next answer said there are 2 o2 Thanks
cartang
Postby Akfahad » Thu Jul 31, 2008 3:02 pm
^^not in Cali if your talking to me. I don't see why it wouldn't work tho, since all you need it for is to satisfy the o2 sensor after the cat. But Dawgz could probably answer that better since he used the other one.
Postby Mr_Krispy1183 » Thu Jul 31, 2008 3:45 pm
Don't mean to threadjack, but just so I get this straight: I'm still in for Dats' Y-Pipe G/B if it goes through. I have a CA spec car, but am going to switch to fed-spec manifolds in order to run the y-pipe. Should I still run the CA-spec simulator afterwards, or will I have to run a fed-spec one? Mind you, I'm in CA, so I need to pass smog.
Postby atclate » Thu Jul 31, 2008 4:04 pm
I think it depends on what signal your ECU is expecting. If you have a Cali Spec ECU, use the Cali Spec O2
For sale: Injen SRI, Randy's CAI extension, TRD Supercharger, TRD RSB, Jim's Torque Rod, 2003 Solara SLE with TRD Body Kit
atclate
Postby Dawgz » Thu Jul 31, 2008 4:27 pm
Mr_Krispy1183 wrote:Don't mean to threadjack, but just so I get this straight: I'm still in for Dats' Y-Pipe G/B if it goes through. I have a CA spec car, but am going to switch to fed-spec manifolds in order to run the y-pipe. Should I still run the CA-spec simulator afterwards, or will I have to run a fed-spec one? Mind you, I'm in CA, so I need to pass smog.
U will need a Type B o2 Simulator from URD. This sends a diffrent signal compared to the Type A. This is because ur car has/had pre-cats on the front header and on the rear header's pipe @ the ypipe. With these two pre-cats, the o2 sensors after the Main cat should be reading diffrently than the federal spec counterpart...and the ecu is looking for that diffrent signal.
Dont worry about smog, ull pass it.
and by the way, u dont have to be in cali to have a cali spec car...im in NJ and have a cali spec car, there are people in cali with federal spec cars....the only way is to look under ur hood and to see if ur front header has a Pre-cat.
Postby facevedo17 » Sat Aug 02, 2008 12:29 am
Im such an dumbb ass .. all these time my car is throwing check engine light ..Im thinking cuz I don't have the O2 sensor after the cat wich I don't I totally forgot about the o2 simulator ........well I already have the sensor just need to put it on I have to think about this one ....
facevedo17
Postby Dawgz » Sat Aug 02, 2008 12:38 am
facevedo17 wrote:Im such an dumbb ass .. all these time my car is throwing check engine light ..Im thinking cuz I don't have the O2 sensor after the cat wich I don't I totally forgot about the o2 simulator ........well I already have the sensor just need to put it on I have to think about this one ....
Is the o2 sensor installed? If not, u will have to install the o2 sensor first....the o2 simulator still needs a functioning o2 sensor for it to work...atleast thats what it said in the manual that i got from URD.
Postby facevedo17 » Sat Aug 02, 2008 12:57 pm
so Vik even If I have the o2 sensor put in after the CAT there is a chance I still have to run the o2 sim ???
facevedo17
Postby Dawgz » Sat Aug 02, 2008 1:52 pm
facevedo17 wrote:so Vik even If I have the o2 sensor put in after the CAT there is a chance I still have to run the o2 sim ???
This o2 simulator serves only one purpose, it sends the ECU the currect signal(voltage) that the rear o2 sensor (after the cat) SHOULD be sending as if everything was stock (the exhaust, etc).
So yes, if u have a modified exhaust system (Headers or ypipe) u probably need to install the o2 simulator.
Users browsing this forum: Google [Bot] and 89 guests
