SolaraGuy.com • View topic - one thing i noticed....
Postby 1gSE » Mon Aug 04, 2008 2:43 pm
i haven't seen many set ups with any kind of ignition amplifier or timing controller? Except for plugs, wires, and the plasmabooster.....
i just read this
http://www.solaraguy.com/viewtopic.php? ... hlight=msd
so fuel is gonna be enough for 7 psi on a decent sized turbo???? :think: sigh...the headaches that come with modding :D Im not looking to blow you sc'ed guys out the water.....or am I.... j/k but seriously, i'm plannin on roughly the same amount of hp some of you guys are making and i'm comparing set ups to what i have in mind. They're very similiar, despite me taking a different route, but a friend of mine brought that up to me
Solara-M62 @ 5.5psi
1gSE
Postby Dawgz » Mon Aug 04, 2008 2:47 pm
ur stock fuel supply will not be enough for any sort of boosting modification.
Ull need to upgrade the pump to a walbro 190lph...possibly 255lph if u plan to be a big whp number guy.
also, injectors.
Postby 1gSE » Mon Aug 04, 2008 3:05 pm
Dawgz wrote:ur stock fuel supply will not be enough for any sort of boosting modification.
also, injectors.
oh i already know fuel isn't up to it. i'm askin about spark
Solara-M62 @ 5.5psi
1gSE
Postby SleeperSolara » Mon Aug 04, 2008 7:38 pm
Yeah i was thinkin' about gettin' a plasma booster for my car....
Wondered if that would add any HP....
Postby 1gSE » Mon Aug 04, 2008 7:47 pm
from what i've read over the years ignition amplifiers usually don't add (much) hp, it just ensures a more complete burn. I wonder if anyone has done anything as far as retarding timing, or if its even necessary at the power levels they're at
Solara-M62 @ 5.5psi
1gSE
Postby Midias » Mon Aug 04, 2008 8:36 pm
I can tell you after playing with an OBD 2 scanner and watching my timing with the plasma booster my car was much more willing to advance timing on at the higher RPMS than without.
Postby gnegroni » Mon Aug 04, 2008 9:00 pm
Midias wrote:I can tell you after playing with an OBD 2 scanner and watching my timing with the plasma booster my car was much more willing to advance timing on at the higher RPMS than without.
Always good to know... Good ignition can help prevent detonation.
gnegroni
Users browsing this forum: Google [Bot] and 89 guests
