SolaraGuy.com • View topic - for those looking to squirt more.....fuel
Postby 1gSE » Wed Aug 06, 2008 1:34 pm
i did some research (ok, i asked a few questions), check it out
Hi, I'm looking for a set of injectors for my Solara. It's a 1999 with the 1MZFE V6. It's a Denso style injector. I need something around 390cc's and the only thing i could find were 310cc and 750cc. If it helps at all, the 2jz non turbo supra injectors will fit on my engine. Will the SL2-0370 injectors fit? The Honda style injectors look a lot like the Denso, would those drop in? Here is a part number for my oem injectors. 23250-0A010
Thank you for your help
Cornell
Thank you for choosing R.C. Engineering. Regarding your previous e-mail, you requested 390cc/min injectors for your 1999 Toyota Solara. We definately have upgrades available in Denso style. The closest size in the Saturated injectors we have is an 370cc/min or 440cc/min injector. The cost is the same. $88.75each. They are in stock. RC injectors are custom modified to fit different applications, so they will fit. You may need to change your injector clips though.
Thank you,
Carol,
R.C. Engineering
Sorry Cornell, one more thing..your oem injector has an air-feed systems, which needs to be blocked off in order to run RC injectors. I mentioned in my previous email that you would need to change the clips. We have two types of clips available, IWC or DCC. The IWC is a cut/splice style at $9.95each and the DCC is a plug/play style at $17.25each.
Thank you,
Carol,
R.C. Engineering
8)
Solara-M62 @ 5.5psi
1gSE
Postby dan99solara » Wed Aug 06, 2008 3:36 pm
nice!
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby SleeperSolara » Wed Aug 06, 2008 9:12 pm
dan99solara wrote:nice!
+ 2.
Postby QuickSEV6 » Thu Aug 07, 2008 8:23 am
I may consider doing this.
I was thinking about getting the Supra injectors (which are plug and play), but they cast $1000 a set. These are only about $600 a set. Nice way to save $400.
Thanks for posting.
Postby Eye8Pussies » Thu Aug 07, 2008 10:57 am
good research....but I don't see how our cars will ever need that much fuel?
to use that much fuel, the engine will have to be full built and putting down at least 400whp. with whichever kind of boost you choose to run...
Postby Dawgz » Thu Aug 07, 2008 11:02 am
QuickSEV6 wrote:I may consider doing this.
Thanks for posting.
1000 from the dealer maybe.
u can get them used and send them into witchhunter to get them cleaned and they should be runnin like new...total cost of the injectors + cleaning shouldnt be more then 200-300
Postby akora12 » Thu Aug 07, 2008 11:35 am
^^^That's what I did and they work perfectly.
Postby 1gSE » Thu Aug 07, 2008 11:42 am
thats what i was tryin to do but it's been over 3 weeks and no parts :-? last time i buy anything off a forum.........so i'll go with something new
Solara-M62 @ 5.5psi
1gSE
Postby Dawgz » Thu Aug 07, 2008 12:57 pm
1gSE wrote:thats what i was tryin to do but it's been over 3 weeks and no parts :-? last time i buy anything off a forum.........so i'll go with something new
3 weeks is nothing.
give it a few more months IF u can.
Look on ebay too..they pop up on there often..
Also, join a supra forum, they get rid of them all the time to upgrade their injectors...and they get rid of them for pretty damn cheap.
Postby CamryOnBronze » Thu Aug 07, 2008 1:02 pm
haham 3 weeks is a long time to wait when you have sent someone money bro...
good info.
Postby Dawgz » Thu Aug 07, 2008 1:03 pm
CamryOnBronze wrote:haham 3 weeks is a long time to wait when you have sent someone money bro...
good info.
OH, i didnt know he purchased it from someone, i thought he meant he was looking for 3 weeks.
my bad.
Postby JavaJoe_2 » Thu Aug 07, 2008 4:50 pm
Theres a couple of sets in the FS section.
One set of RC's 318cc of which are mine.
These should do you just fine.
I also have 370cc in my Solara but I'm dyno'ed at 325 fwhp.
I still think that they are overkill but seem to be working fine for now. :bday:
Got Boost?? :sweet:
JavaJoe_2
Postby Dawgz » Thu Aug 07, 2008 4:53 pm
JavaJoe_2 wrote:Theres a couple of sets in the FS section.
wow, nice power out of silverlicious.
Postby SleeperSolara » Thu Aug 07, 2008 8:48 pm
For real.
I agree.
:o
Users browsing this forum: Google [Bot] and 94 guests
