SolaraGuy.com • View topic - Shocks, Springs, n stuff... help?
Postby BLACK V6 » Fri Aug 08, 2008 10:02 pm
Most of these SG guys r telling me I need to lower my ride so I guess im gunna go for it. I just need some advice. The previous owner of my wheels had a rubing problem. He had a solara and it had a 2" drop. 1st off, I do not want to have a rubbing problem. At this point in my budget I cant deal with it. 2nd I need the cheapest way to do it. Anyone have any suggestions? Thanks
BLACK V6
Postby LostSoul » Fri Aug 08, 2008 10:11 pm
u know what thats the lo profile tire there actually is.
your tires look fat for some reason what about trd springs it's not that much of a drop!
LostSoul
Postby ThatVietGuy » Fri Aug 08, 2008 10:26 pm
Cheapest way is to buy Tein springs and use your stock struts.
ThatVietGuy
Postby BLACK V6 » Fri Aug 08, 2008 10:32 pm
how much of a drop should I get if I don't want to rub?
BLACK V6
Postby ThatVietGuy » Fri Aug 08, 2008 11:10 pm
Well, it's all on the specs of your wheels and tires. What are the size of the tires and the dimensions of the rims (particularly offset)?
ThatVietGuy
Postby blaK » Sat Aug 09, 2008 5:28 am
Yea but look how nice she looks. :)
It only rubbed when I was going thru the intersection ( that hump in the road ) and driving fast, then it would rub but for a hot second. Plus I had a sub box that weighed almost 100lbs. Other than that, I had no problems.
Plus most guys here put 40's, I only went with 45's cause of possible pot holes.................there's none here!!!!!!
Tokico struts and teins springs is what I had.
Next step stiffer would be Trd's set up.
P.s
Tint that!!!!
blaK
Postby Midias » Sat Aug 09, 2008 6:41 am
save your money and do it right with quality struts and nice springs that way you only have to take it apart once and don't forget the alignment.
Postby BLACK V6 » Tue Jun 02, 2009 6:34 pm
I know this is an old thread but I didn't feel the need to start a new one. I am getting my Teins I recieved today put on tomorrow. Ill be sure to do a before and efter. And one question. Is there any need to cut the bump stops? Do I need to make sure to tell the shop to do that too?
BLACK V6
Postby t3chnique » Tue Jun 02, 2009 6:49 pm
took u a year to finally get em?
t3chnique
Postby nemoxfishy » Tue Jun 02, 2009 6:58 pm
I have Teins and I cut my bump stops...
Ride is smoother IMO. I don't bottom out as much.
nemoxfishy
Postby ASG14 » Tue Jun 02, 2009 7:03 pm
No, don't cut your bump stop. It;s there for a reason. If they are causing an issue, there are things that need to be replaced to stop it from happening.
And I hope your either using new struts, or the current ones do not have many miles on them.
ASG14
Postby BLACK V6 » Tue Jun 02, 2009 7:16 pm
ASG14 wrote:No, don't cut your bump stop. It;s there for a reason. If they are causing an issue, there are things that need to be replaced to stop it from happening.
About that. I thought about getting new struts I just don't have the $$ right now. I'm just gonna do the job half assed and hope for the best lol. Oh yeah, and the TEIN manual said to cut them. Thay said, for 99-03 solaras 1" in front and 1.4" in rear.
BLACK V6
Postby t3chnique » Tue Jun 02, 2009 7:32 pm
I wouldnt half ass any suspension if I were u.
t3chnique
Postby BLACK V6 » Tue Jun 02, 2009 7:44 pm
I wouldn't call it half ass I was exaggerating. Other members have done this setup it seems to be fine. Anyways if it doesn't work out ill fix it. Pics to come tomorrow. I might do a vid of some sort too cuz i don't have anything going on.
BLACK V6
Postby ASG14 » Tue Jun 02, 2009 7:45 pm
t3chnique wrote:I wouldnt half ass any suspension if I were u.
:drinking:
Check out my thread from the last 2 days. This is what happenes when you half ass crap. Have fun when you screw up your car.
http://solaraguy.com/viewtopic.php?t=45231
ASG14
