SolaraGuy.com • View topic - Subwoofer - Cover or Not?
Postby BLACK V6 » Sat Aug 09, 2008 8:06 pm
I will be installing a JBL sub that I bought on monday. The audio guy reccommended that i buy a cover to go over the speaker cone. This speaker has a nice design on it so I dont think I would want to cover it. I am installing it in the rear deck also so it will be very visible. What is the risk of damage. Here is a pic of it. Should I cover it and be safe, or should I leave it open for show?
BLACK V6
Postby BLACK V6 » Sat Aug 09, 2008 8:14 pm
WOW, SG is kina a ghost forum tonight. :o
BLACK V6
Postby TLMNICK » Sat Aug 09, 2008 8:25 pm
How exactly do you plan to mount it to the rear deck?.....are you gonna make a huge hole?
If so, I highly advise against it because those subs are not designed to be used with no box. With that in mind, it'll more than likely cause a lot of unwanted vibrations, and it'll sound horrible.
My recommendation is to put it in a decent box in the trunk, and upgrade your 6X9'S on the rear deck instead. You'll be much happier with the end result.
Also keep in mind that having the speaker mounted in the rear deck, it will be directly exposed to the sun, which will damage it over a short period of time.
TLMNICK
Postby BLACK V6 » Sat Aug 09, 2008 8:41 pm
Ive already had a sub in the rear deck before and it sounded fine so there is already a hole. I was worried about the rattling too but it didnt do any rattling. Actual the owner of the audio place told me to use that sub in the rear deck in open air. IDK, i hope he is right...
BLACK V6
Postby Mr_Chunkz » Sat Aug 09, 2008 10:34 pm
EH?
why not a trunk box dood
is that an 8" sub or something?
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Jakecallun20 » Sat Aug 09, 2008 10:36 pm
BLACK V6 wrote:Ive already had a sub in the rear deck before and it sounded fine so there is already a hole. I was worried about the rattling too but it didnt do any rattling. Actual the owner of the audio place told me to use that sub in the rear deck in open air. IDK, i hope he is right...
I have NEVER EVER heard of a rear deck mounted subwoofer....EVER. IMO that will sound horrible. But to each there own. And if thats the case, I'd opt for the speaker grill because if its exposed...everyone will be able to see it....do you have an alarm system?? Do you see where this is going?
Postby BLACK V6 » Sat Aug 09, 2008 10:42 pm
yea, I see. I already have a rs3000 VIP security system.
BLACK V6
Postby Jakecallun20 » Sat Aug 09, 2008 10:44 pm
BLACK V6 wrote:yea, I see. I already have a rs3000 VIP security system.
Is that the stock alarm system? If so...Idk how much that will stop. I've already found a few flaws in it, ways around it.
Postby TLMNICK » Sat Aug 09, 2008 11:26 pm
Well to each his own, but I for myself MUCH prefer to have my audio components placed in such a way where they can be heard and not seen. I dont want to judge your audio setup here, but what I have pictured in my head is lookin pretty ghetto. Is there just a big hole, or did someone actually build a proper speaker panel for it? I've been doing the whole car audio/security thing for years now, and in my experience, no free-air sub will ever sound better than a sub mounted in its own box built to specs.
And in terms of your security, the stock toyota VIP units are not difficult to work around. The glass break sensor on those things dont work too good either.
TLMNICK
Postby BLACK V6 » Sat Aug 09, 2008 11:43 pm
I can totally understand where you are coming from. I already have it set up for this arrangement so I will go ahead and do it.The professionals at my local audio center recommended me to that setup and that sub. They said that they had installed many like that before and turned out just as good, if not better than an enclosure/trunk setup. I will post pics on monday after installation. Thanks for ur input.
BLACK V6
Postby Jakecallun20 » Sun Aug 10, 2008 11:50 pm
BLACK V6 wrote:I can totally understand where you are coming from. I already have it set up for this arrangement so I will go ahead and do it.The professionals at my local audio center recommended me to that setup and that sub. They said that they had installed many like that before and turned out just as good, if not better than an enclosure/trunk setup. I will post pics on monday after installation. Thanks for ur input.
Np man, I hope it goes well, do post up when you get it installed, I want to see it in the rear deck! 8)
Postby BLACK V6 » Wed Aug 20, 2008 3:40 pm
Yea, Yea. Okay u guys wer right. It sounds alot better in a box. Which I bought ONLY because you reccommended it lol. Here is a pic.
BLACK V6
Users browsing this forum: Google [Bot] and 89 guests
