SolaraGuy.com • View topic - bad hid output
bad hid output
bad hid output
Postby prsolara » Sat Aug 16, 2008 8:21 pm
I dont know what is the problem I am having with hids. First I haved 10000k bulbs on my car then changed it cuz the light output wasnt too good, then i switched to 6000k bulbs but isnt bright and the light output i think that is low than the 10000k bulbs. IAnyone haved this same situation or know if it is a problem with theheadlights that I need to align/aim. I need some help so please any tips will be appreciated. Thanks
prsolara
Postby NeFaRiOuS_SLE » Sun Aug 17, 2008 12:19 am
Well, all bulb compositions and focus varies, so re-aim it if you haven't already done so. If not, try re-focusing the beam too. But either way, the higher you go in K ratings, the lower quality the light, so don't switch back to 10,000 again.
Postby prsolara » Sun Aug 17, 2008 7:46 am
^^yea I know that the more k less bright it is thats why I switched to 6000k but I dont see any difference... I will that today re focuse the beam. Also the beam has like a metal sheet in the beam, how it have to be? down or up? I dont know how to explain, when i get a chance I will snap some pics and thanks nefarious!!
prsolara
Postby NeFaRiOuS_SLE » Sun Aug 17, 2008 10:03 am
Metal sheet? I'm not quite sure I follow. Please DO post pictures.
Postby prsolara » Sun Aug 17, 2008 2:04 pm
The bulbs havet these thing Image
dont know why they have this, and also dont know if this is the cause of the bad output.
prsolara
Postby hskrsolara » Sun Aug 17, 2008 2:06 pm
mine had that as well, I just left them in...I figured the shields would help the beam pattern?
hskrsolara
Postby prsolara » Sun Aug 17, 2008 2:20 pm
yeah and the glare, but how you put them? with the shield down or what?
prsolara
Postby mazen222 » Mon Aug 18, 2008 5:49 am
prsolara wrote:yeah and the glare, but how you put them? with the shield down or what?
ya.. i was wondering the same thing... I installed my hid 2 weeks ago. The one on the left is perfect output, but the one on the right side i almost dont see it on the floor. im sure its just a mater of playing with the hight.
i placed those metal sheets you're refering to on the side, closest to the edge of the car.... to avoid loosing light from the sides.
btw, there are 3 litle taps on the outter circomference of the bulbs, are these supposed to fit in the spaces inside my headlights? kuz they dont.
mazen222
Postby prsolara » Mon Aug 18, 2008 10:29 am
yep, thats suppose to be in the spaces in the headlights cuz they help the bulb to not move.
prsolara
Postby mazen222 » Mon Aug 18, 2008 8:12 pm
but they dont fit in those holes... i would have to break one of them... is that normal?
mazen222
Postby prsolara » Wed Aug 20, 2008 4:52 pm
nop thats not normal bring some photos if you can.
prsolara
Postby NeFaRiOuS_SLE » Wed Aug 20, 2008 11:05 pm
You might have it installed incorrectly (upside down) if you have to break something. If I remember correctly, the inside of the curve has to be facing up.
Users browsing this forum: Google [Bot] and 31 guests
