SolaraGuy.com • View topic - Please post pics of your engine bays showing grounding kits.
Postby Solorange » Fri Aug 22, 2008 11:04 am
Kevin TMMKToy asked me to post this for you guys so he can have some ideas by the time he gets home from work so he can do this to his car tonight. He is interested in the 1MZFE engine bays. Thanks Chris
Postby ASG14 » Fri Aug 22, 2008 11:26 am
I've never even seen a grounding kit on any 1MZ.....
ASG14
Re: Please post pics of your engine bays showing grounding k
Postby Dawgz » Fri Aug 22, 2008 11:39 am
Solorange wrote:Kevin TMMKToy asked me to post this for you guys so he can have some ideas by the time he gets home from work so he can do this to his car tonight. He is interested in the 1MZFE engine bays. Thanks Chris
Postby CamryOnBronze » Fri Aug 22, 2008 11:42 am
he wants to see grounding kits on a 1mz... it isnt that hard to understand bro :lol: funny gif though
Postby Dawgz » Fri Aug 22, 2008 12:03 pm
ASG14 wrote:I've never even seen a grounding kit on any 1MZ.....
I believe silverlicious has a grounding kit....
Postby Mr_Chunkz » Fri Aug 22, 2008 12:21 pm
HKS Circle Earth Grouding System?
purple wires.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby lilm » Fri Aug 22, 2008 1:08 pm
just replace the stock ons with a lower gauge
lilm
Postby Chinky420 » Fri Aug 22, 2008 1:21 pm
i have grounding wires, but no pics (also @ work)
but from memory i have them daisy chained as follows:
neg terminal --> chassis
(from chassis i have)
-->chassis --> stock ground point (near transmission bell) --> engine ground point (between the front bank and rear bank, drivers side).
-->chassis --> throttle body --> far side of intake plenum (pass side) --> passenger side stock ground point
-->chassis to engine block (middle-ish bolt, same as tracy's)
the chassis point has multiple terminal rings stacked upon each other (if you couldn't figure it out from the way i wrote it). i used 4AWG wiring, and gold terminals from knukonceptz.com, and made my own (hence no negative grounding plate, as in tracy's setup, where all the wires hook into the neg term).
Chinky420
Postby SleeperSolara » Fri Aug 22, 2008 9:12 pm
I just replaced all the OEM wires wit thicker AWG wires.
I'm thinkin' about uppin' the AWG thickness soon.
For my negative ground i have a 0 AWG from the tranny housin' to post clamp.
The other wire from under the battery tray is a 4 AWG wire.
Postby Midias » Mon Aug 25, 2008 7:06 pm
Users browsing this forum: Google [Bot] and 31 guests
