SolaraGuy.com • View topic - 3mz/1mz hybrid engine
Postby Gregtrd » Tue Aug 26, 2008 12:42 am
A quick update on the progress of my 3mz/1mz supercharged set up, I have now replaced my stage 3 clutch(spec) with a new one and still breaking it in, only 200 miles on it. With the 1mz set up I was boost'n 5.5 psi it pulls petty hard but now with the 3mz in there it pulls way stronger, and my boost gauge now only read a steady 3psi at full throttle, at high rpm 6k to about redline it'll creep to 3.5 to 4psi. can't wait to dyno. I'm thinking of building another 3mz/1mz hybrid if anyone is interested it'll be a straight drop in, down time should take 1 day(actually 8hrs ask tracey). As soon as i dyno my car I post a dyno sheet.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby lilm » Tue Aug 26, 2008 12:49 am
does your engine have forged internals?
lilm
Postby Gregtrd » Tue Aug 26, 2008 12:54 am
lilm wrote:does your engine have forged internals?
Not yet. I think gabe does though. I'm thinking later on for me. I'm going with the 6psi pulley 2.8 that should keep the boost at 4psi.
Gregtrd
Postby lilm » Tue Aug 26, 2008 12:57 am
its so tmepting but i really want to get something rwd.....about how much will this cost?
lilm
Postby Gregtrd » Tue Aug 26, 2008 1:04 am
lilm wrote:its so tmepting but i really want to get something rwd.....about how much will this cost?
Not sure yet, all I need so far is the 3mz block, head gaskets,and power stiring pump 3mz of course.I'm very surprise how strong it pulls with only 3 psi.
Gregtrd
Postby lilm » Tue Aug 26, 2008 1:13 am
id love to see some dyno numbers i cant wait
lilm
Postby Mr_Chunkz » Tue Aug 26, 2008 3:33 am
lol greg
8 hrs labor
its no BS guys it really only took 8 hours for him to motorswap.
Greg u gonna build a built 3mz for me one day :D
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Gregtrd » Tue Aug 26, 2008 8:12 am
Mr_Chunkz wrote:lol greg
8 hrs labor
I think you'll need it soon.
Gregtrd
Postby CamryOnBronze » Tue Aug 26, 2008 8:28 am
:lol:
very nice greg, if I was out in cali Id consider it, but I too am done dumping money on the solara :lol: props!
Postby panic » Tue Aug 26, 2008 8:37 am
Duh, but exactly which parts are 1MZ and which are 3MZ?
panic
Postby Eye8Pussies » Tue Aug 26, 2008 9:07 am
good to hear....can't wait to see those dyno sheets to compare!
so I gather that you're only running the 4psi pulley right now?
Postby Sebas007 » Tue Aug 26, 2008 9:22 am
panic wrote:Duh, but exactly which parts are 1MZ and which are 3MZ?
block & internals come from 3MZ the rest is 1MZ (head)
Postby panic » Tue Aug 26, 2008 9:41 am
Where do you think the power comes from, just the extra bore size? Compression?
panic
Postby Sebas007 » Tue Aug 26, 2008 10:11 am
panic wrote:Where do you think the power comes from, just the extra bore size? Compression?
I'm sure it is the higher bore. The compression should be the same since the stroke is the same and the head remains also the same. Maybe the bore makes the compression rate decrease a bit compare to a stock 1MZ.
Postby Gregtrd » Tue Aug 26, 2008 10:16 am
Eye8Pussies wrote:good to hear....can't wait to see those dyno sheets to compare!
No I running my 5.5 pulley, but with the 3mz block, it only reads 3psi, so I'm going with the 6psi pulley, ill play it safe for now. I think that the reason for the psi drop is because the pulleys are intened for a 3.0 an not a 3.3 engine.
Gregtrd
Users browsing this forum: Google [Bot] and 31 guests
