SolaraGuy.com • View topic - Guys, don't be mad... Another HID question.
Postby SolaraMan7890 » Tue Aug 26, 2008 8:36 pm
Sorry, but I searched and nothing seemed to fully answer my question...
I have a Gen. 1 and am thinking of upgrading to HID. I have a very low budget, but obviously want my HIDs to last me. I found the 60-70$ hids on eBay, and the VVME.com HIDs, and am interested in buying either, but one thing, i dont understand, am I supposed to get the Bi-Xenon headlights, or the regular one beam?
I always thought that the Solara had a turning mechanism on the high beam, where it aimed the beam higher, so wouldn't it not matter if the bulb is bi-xenon? I dont understand... I want my high beams HID tho.
2000 SE.
SolaraMan7890
Postby Ilovemylara » Tue Aug 26, 2008 8:42 pm
you would probably need the bi-xenon headlights... Im not exactly sure. I have a gen1.5 (dual bulb per headlight)
Postby SolaraMan7890 » Tue Aug 26, 2008 8:48 pm
Right, I know that for the 1.5 people need a separate bulb for the high beam in order to be HID, but the gen 1 comes with only 1 bulb which does both, hi and lo.
2000 SE.
SolaraMan7890
Postby Ruski » Tue Aug 26, 2008 8:50 pm
No, the gen 1.5 have two sperate bulbs one high one low , the gen 1 has one dual filiment bulb,you need bi xenon bulb if you want to run hi and low beam
Postby SolaraMan7890 » Tue Aug 26, 2008 8:52 pm
^^ what if I just get a regular one beam? the lo will be hid and the hi will just be halogen??? even though the bulb thats running is an HID?
2000 SE.
SolaraMan7890
Postby facevedo17 » Tue Aug 26, 2008 9:26 pm
that depends on the kit you get .
some Bixenon kit have one hid bulb that does both functions H/L
and other kits have an hid bulb for L and a mini halogen for your highs...
facevedo17
Postby SolaraMan7890 » Tue Aug 26, 2008 9:30 pm
... ok in other words, which of these two are worth getting? ...and are these (from this company) worth getting??
http://www.vvme.com/catalog/list-s-10145-10146.html
2000 SE.
SolaraMan7890
Postby Mr_Chunkz » Tue Aug 26, 2008 9:53 pm
:o those are about 1/4 the price i paid for my HID
but i got mine from
http://www.s2ionline.com
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby SolaraMan7890 » Tue Aug 26, 2008 10:23 pm
yea... haha my budget is kinda low, so i've been doing lots of research... i just hope they dont go out on me after a couple months... perhaps ill just get the $40 ones, thats less than a tank of gas...
2000 SE.
SolaraMan7890
Postby nj99solara » Thu Aug 28, 2008 10:59 pm
SolaraMan7890 wrote:... ok in other words, which of these two are worth getting? ...and are these (from this company) worth getting??
If you get the single beam kit you won't have any high beams, I suggest the bi-xenon kit.
-4500k HID Bi-xenon kit
-4500k HID Fogs
-5% Tint in rear
-Tinted Stock Taillights
-Shaved Emblems
nj99solara
Postby krook » Fri Aug 29, 2008 4:36 am
werd. mines is like that. it comes in handy though whenever i want to turn off my HID's when the engine is on. just put the highbeam on, and POOF no blinding light.
krook
Postby mazen222 » Thu Oct 02, 2008 4:22 pm
wow... sorry to bring this thread back from the dead but to be clear here
Bi-xnon on the 99 solaras will give you xenon on the low beam and xenon on the high beam
the normal xenon ones will give you xenon on the low beam and normal filament light on the high beam... you still get high beam but its just not xenom
1999, 5 Speed V6
mazen222
Postby NeFaRiOuS_SLE » Wed Oct 15, 2008 10:35 pm
^Well, neither of them are good (especially the ones that have a halogen bulb and a xenon bulb... that's just asking for any negative consequences), but I have the kind that flicks the light up when you need high-beams (usually only useful for overhead signs or flashing them at night when someone cuts you off or something).
Postby someazn » Thu Oct 16, 2008 12:01 am
Do it once and do it right is always the rule i stand by. Never get the ebay kits and the vvme kits, their ballast draws more power than what is rated. I had a vvme kit and it blew my 10 amp fog light fuse. Turns out it was drawing more power than usual since it didn't blow out a 15 amp fuse. These kits also tend to flicker. Xenon + Halogen does not equal bi-xenons, more like Xenogens :roll:
I recommend www.retro-solutions.com
They have lifetime warranty on their kits so you never have to worry about it going out. I believe the failure rate to date on their kit is something like 0.05% and they've been around for a few years. Unlike other cheaper imitations, their bi-xenon bulbs are actually motorized with the bulb moving in and out. Well respected on many forums. I've never had any problem claiming warranty and their service is always great. See what you like, but don't order from their site. They sell their kits on ebay for cheaper, about $170. Hope that helps.
someazn
Users browsing this forum: Google [Bot] and 31 guests
