SolaraGuy.com • View topic - shocks and K&N questions....
Postby p-phunck » Wed Jun 18, 2003 8:26 am
man...u guys are quick wit the responses...
anyhow, i need new shocks...what kind should i get??? gas pressurized??? brand???
and im noticing alot of ppl on our forum have k&n air fitlers...what do they do for the car??? any performance difference??? any difference between the k&n and the stock????
ty solara fans again
[99' SLE V6 ~ Tokico/Tein ~ K&N ~]
p-phunck
Postby DavPak » Wed Jun 18, 2003 8:29 am
for shocks your best bet are Tokico HP gas shocks.
lots of us here are running them and i've yet to hear a problem.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Fletch » Wed Jun 18, 2003 9:26 am
If your air filter needs to be replaced, I would go ahead and get the K&N because you can clean and reuse it. There isn't any noticable performance increase though.
You might want to remove the upper and lower resonators on the intake. It won't cost much and it makes the intake a little louder, if that's your thing.
2006 Legacy GT spec.B
Fletch
Postby SunGod916 » Fri Jun 20, 2003 4:22 am
Practically anything will alter the sound of your intake. I opened up the air filter housing to air blow out the filter, and when I snapped the housing back together, I must have missed the far snap below, because there was an air leak. I only noticed the first I had to mash it. The car sounded different, but it was a good different.
Needless to say, I fixed it right away.
SunGod916
Postby FLASH » Fri Jun 20, 2003 6:13 am
How would I remove the resonators and is there any potential damage in doing so?
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Fletch » Fri Jun 20, 2003 6:44 am
The lower intake resonator is easier to do:
-Remove the LF wheel
-Loosen the fasteners on the fender liner and peel it back to reveal a white object located in the LF bumper behind the fog light, it's about the size of a volleyball
-it's held in by 2 bolts, just take it off and forget about it
To remove the upper intake resonator, you will need to replace it with a 5" long 2.75" diameter pipe or tube and an air breather to replace the valve cover vent hose that goes to the resonator.
Fletch
