SolaraGuy.com • View topic - JIC Coilover Questions.
Postby Toy1mzfe » Mon Sep 01, 2008 11:34 pm
Is it just me or is the coilovers stiff like a mofo?
So i installed the Flt-a1 and it is quite stiff.
Its to a point where i feel like im not even on my seat.
Also there are gas sounds coming from the back struts.
So i live in the city, and i have bumps everywhere. I feel everything.
My first time dealing with coilovers, is this how it is?
Tein guys and Jic guys. How is your experience?
Also, whats your settings on the FLT's?
Postby lilm » Mon Sep 01, 2008 11:43 pm
ummm ya dude what did you expect? The jic's are the stiffest ones out there.
lilm
Postby Toy1mzfe » Mon Sep 01, 2008 11:44 pm
haha, really i had no clue what i was getting myself into.
Postby i20solara02i » Mon Sep 01, 2008 11:45 pm
ya the jic's are one stiff coilovers not as soft as the teins but handling is very nice
i20solara02i
Postby lilm » Tue Sep 02, 2008 12:17 am
lol :drinking: i still got to send mine in to jic
lilm
Postby Mole » Tue Sep 02, 2008 12:19 am
get used to the like of riding on rocks.
Postby Toy1mzfe » Tue Sep 02, 2008 12:40 am
i have a feeling that i may have these on sale soon.
San Francisco+Daily Driver= not too friendly on the body.
Postby lilm » Tue Sep 02, 2008 3:31 am
weak dude. Its just a little back pain BE A MAN lol
lilm
Postby CASTRO » Tue Sep 02, 2008 7:07 am
if you think the FLT-A1's are bad, you should feel my setup. lol custom higher springrate w/matched shock valving FLT-A2RS's.
Also running a whiteline front anti-sway bar to add to the fun.
Handling goodness.. :)
CASTRO
Postby panic » Tue Sep 02, 2008 10:09 am
The lower the car is, the stiffer the spring must be to prevent accidental removal of the exhaust system.
Increase the lbs. per inch deflection rate also limits the total amount of travel, so the camber pattern is shorter.
The rule for spring rate (road race) used to be to get the car height where you need it for aero, downforce etc. then decrease the rate to where the car just touches the compression stops at the worst part of the course. If it never touches, the suspension isn't properly loading the wheels and using full suspension travel to prevent the chassis from being affected by road surface changes. Be very careful about moving the compression stops - when the suspension hits them, that spring rate goes to near infinity and the wheel has zero traction.
The only downsides to loose springs is excess camber change and bottoming. If it wallows, stiffen the shocks. Using heavy springs to control body roll isn't effective - play with your bars.
panic
Postby M_ABILLONES » Tue Sep 02, 2008 10:31 am
Welcome to the coilover world! Coilovers are meant to be stiff since it's designed or geared towards a more aggressive driving style. My Tein Flex on my WRX feels like the car has rigid suspension. The "sound" you're talking about is normal. All coilovers do this. Now if you hear cracking or pinging sound then you have a problem!
M_ABILLONES
Postby Toy1mzfe » Tue Sep 02, 2008 11:49 am
First time with coilovers, so im very new to this.
So far, its not too bad. I think it was more on setting the dampening the way i wanted.
Frigging handles very very nicely.
Postby SleeperSolara » Tue Sep 02, 2008 6:51 pm
You should be able to adjust the dampin' settin's.
I wish i could get some coilovers.
Coilovers = bling for me. :lol:
Postby CamryOnBronze » Tue Sep 02, 2008 7:49 pm
man, I loved those JICs... they may have made me sterile though :lol: but yeah my mechanic said the gas sounds from the rear are normal as well, they did that on my car the whole time I owned them. Sorry theyre so harsh for your liking man!
Postby 1st Gen Sol » Tue Sep 02, 2008 8:06 pm
^^ x2. I just recently installed the a2's not too long ago. I had them on the stiffest setting and had to adjust them a bit, New York roads are not forgiving when you hit dips, bumps, potholes, or roads cut out leaving the rough gravel underneath.
You just have to adjust them to your liking, eventually you'll get use to them. Great purchase, don't sell them, especially since you just got them.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Users browsing this forum: Google [Bot] and 95 guests
