SolaraGuy.com • View topic - Jp Performance 3" Cat-Back Dyno Results
Postby EricSol » Thu Jun 19, 2003 6:49 am
I was on the dyno last night and made 13 more hp at redline with NO LOSS and even a slight gain at low rpm. I had a custom 2 1/2" catback before with the Jp Headers. The 3" system has 2 resonators and a Stainless Magnaflow and is quieter then any of the aftermarket catbacks I have heard with the Jp Headers. It will be removed from my car today and jigged so it can go into production next week.
Jp will also be releasing 2 different Y-Pipes next week, for cars with and without pre-cats. There will be package deals on the Y's with the catback and on the Headers with the catback. For all previous Header customers Jp will have special pricing on the 3" Catback.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby Ragtop George » Thu Jun 19, 2003 3:04 pm
This makes sense. For the kind of horsepower (300+ at the crank) you are running, you should need a 3" exhaust if it is single. As long as the primaries on your headers are smaller diameter to encourage scavanging, you want max flow after that.
So what HP are you up to now?
George
2002 Solara Convertible Automatic
TRD Supercharger, 6 PSI pulley
Apexi WS exhaust, custom Y pipe
TRD RSB on "track" setting
Ragtop George
Postby EricSol » Thu Jun 19, 2003 3:27 pm
The Dynojet I have been using isn't as liberal as Area51's so my best is a 267fwhp.
Ragtop George wrote:This makes sense. For the kind of horsepower (300+ at the crank) you are running, you should need a 3" exhaust if it is single. As long as the primaries on your headers are smaller diameter to encourage scavanging, you want max flow after that.
George
1999 Solara 296 whp
EricSol
