SolaraGuy.com • View topic - TRD Supercharger for 2004
Postby dcpedit » Thu Jun 19, 2003 5:29 pm
Does anyone know if the the current supercharger will be compatible with the more powerful 2004 Solara? If not, when will TRD come out with a new version?
Thanks,
dcpedit
dcpedit
Postby Yanks0114 » Thu Jun 19, 2003 6:24 pm
The current one will not work. It is a lot more difficult to get a supercharger to work with an engine that has VVTI like the new one. TRD is currently working on a new version, but it could take a while before its actually available
Postby SunGod916 » Thu Jun 19, 2003 6:25 pm
Not only that, the new engine for the Solara will be bigger. I will be 3.3 liter if I remember correctly, instead of the 3.0 liter in the car now. The engine will be the same one that is currently in the Sienna.
SunGod916
Postby NASTY » Thu Jun 19, 2003 6:28 pm
nope, definitely not compatible!
'01 SLE V6
NASTY
Postby Jackass-Jeff » Fri Jun 20, 2003 8:55 am
SunGod916 wrote:Not only that, the new engine for the Solara will be bigger. I will be 3.3 liter if I remember correctly, instead of the 3.0 liter in the car now. The engine will be the same one that is currently in the Sienna.
it's the same engine as the current except that it has been bored out to 3.3L it's not a true redesign... it's just slightly larger w/ VVT-i.
I thought S/C wouldn't work w/ any sort of variable valve timing... All you have to do is switch the ecu to work w/o the vvt-i and the old s/c should work. -_- but what a waste of vvt-i capable hardware =P
1GR-FE ftw!
Jackass-Jeff
