SolaraGuy.com • View topic - Brakes
Brakes
Brakes
Postby GreenSolara01 » Mon Sep 22, 2008 7:50 am
I’m looking for a new brake set up. I was thinking of Hawk pads, but didn’t know if I should just change out everything. Basically my pads are cheap Minike pads with a lifetime warranty, but the squeak all the time. They do the job but I hate them. I also wanted to upgrade my lines to some Stainless steel ones. I think the o.e. calipers do a good job but I’m open to suggestions.
Any ideas for a good brake set-up?
GreenSolara01
Postby BChad200 » Mon Sep 22, 2008 10:31 am
hawk pads, brembo or powerslot rotors and stainless lines is a good start. also get some dot4 high temp brake fluid. or if you can find a set/afford them you could get the supra brackets and put on the larger supra rotors.
also, i recommend getting just drilled rotors for a daily driver. slotted ones eat up your pads faster but it'll definitely stop faster.
2000 Solara SE V6 5 speed- driven for fun
1994 Mazda B3000 SE Cab Plus 2wd Auto- driven for everything else
BChad200
Postby Akfahad » Mon Sep 22, 2008 12:51 pm
I've got R1concepts drill and slotted rotors with Axxis pads in the front, stock pads in the rear (only because the rear pads didn't fit). Love them, never had problems and the pad wear is actually really good, still have plenty left and installed them maybe two years ago. i also just bought a set off ebay for my other car...
Postby GreenSolara01 » Mon Sep 22, 2008 7:21 pm
What will the DOTIV do for me? I am interested in the bigger supra rotors, do the calipers still work, could they be replaced with supra calipers as well?
GreenSolara01
Postby TadS » Mon Sep 22, 2008 7:32 pm
Supra TT rotors w/ the Ericsol kit & SS hoses is the best bang for buck IMHO. You'll use the OE calipers and standard pads. Personally I like EBC pads, but they wear pretty quick. DOT IV has a higher boiling point. I run it, but really probably don't need too.
TadS
Postby r0w » Mon Sep 22, 2008 9:49 pm
^^ Agreed! If you want a set of Ericsol kit w/ bolts and washers let me know.
r0w
Postby boneezy » Tue Sep 23, 2008 12:17 am
i agree. ss lines are awesome. you get rock solid pedal response, i definitely recommend it
1999 SE-V6 5spd
160,xxx miles
boneezy
Users browsing this forum: Google [Bot] and 31 guests
