SolaraGuy.com • View topic - Revival of the EricSol Brake Upgrade
Postby lightear » Thu Oct 02, 2008 6:56 pm
First of all, thanks to Sp33d for making this happen. I've always been jealous of those who had the kit. I'm thankful for this resurrection and it couldn't have happened unless Sp33d made the move. Thanks again, Mark! (<-- aka Sp33d).
Here is before:
And now here is after:
And here is the comparison of the two rotors:
Reflections:
Had a bit of issues from initial install. I had thought that this was just plug and play but it turns out that there was a very minor rubbing issue with the brake pad brackets against the new rotor as well as a fitment issue. After correcting the two issues rubbing noise went away and my stopping power is definitely noticeable (almost dramatic, but I don't wanna sound....dramatic).
I only changed the rotors and pads so i'm still using stock brakelines therefore the slight feel of shaking was reduced a bit but neverthless still remained. I will change out the brakelines in due time to see what the improvements are. But again, stopping power for me has been noticeably better and stronger.
I will post more pictures and explanations of what i had to do to correct the issues.
Good luck to all of those who plan on doing this mod.
lightear
Postby Ruski » Thu Oct 02, 2008 7:17 pm
That looks sick man, big improvement
Postby SleeperSolara » Thu Oct 02, 2008 9:04 pm
Nice man.
Hopefully i can get my hands on a set soon.
Postby Toy1mzfe » Thu Oct 02, 2008 10:01 pm
DAm, those look hot under your shoes.
Just a quick question- how you know what side those rotors are suppose to be facing? Like according to the slots.
Postby (K) » Thu Oct 02, 2008 11:41 pm
^^My friend, the rotors only go on one way.
Unless you meant front or rear?
Those rotors are looking good; fills out reeeaaalll nice behind those wheels!
(K)
Postby lightear » Thu Oct 02, 2008 11:43 pm
Toy1mzfe wrote:how you know what side those rotors are suppose to be facing? Like according to the slots.
Good question. Took me some research to figure that out too. It's not about the direction of the slot. What matters is how the air cools the rotors. There's some air space in the center of the rotor. If you let it stand on its edge from looking top down you can see that some rotors are designed to cut in to the air so that air will flow through the rotor. You just gotta spin the rotor and figure out if the grooves are cutting in to the air or not. If they are then they are spinning the right direction
lightear
Postby (K) » Thu Oct 02, 2008 11:46 pm
Oh you meant the vanes...whoops my bad...
Yea, vanes are against rotation.
(K)
Postby Toy1mzfe » Thu Oct 02, 2008 11:52 pm
lightear- thanks for the info.. i have a feeling mine is in reversed... hmm oh wells cant be that bad.
Postby lilm » Fri Oct 03, 2008 7:48 am
just curious....why is braking better? i man you still have the same amount of contact of pad/rotor, correct?
lilm
Postby akora12 » Fri Oct 03, 2008 8:13 am
Very nice, that looks hot. Are those the stoptech rotors?
Postby no_escape » Fri Oct 03, 2008 8:14 am
lilm wrote:just curious....why is braking better? i man you still have the same amount of contact of pad/rotor, correct?
The slots remove brake dust, making for better contact of the pad to the rotor.
The drill holes help cool the rotor. A hot rotor and/or brake pads will make it harder to stop braking sooner.
Even if your contact area is the same, with drilled/slotted rotors you should have better braking. Maybe not a massive difference but there should be a difference.
no_escape
Postby CASTRO » Fri Oct 03, 2008 8:16 am
just think of a spinning bike tire or see-saw.
Would you rather push/pull from the inside for less TQ or grip it from the end for more power?
Also just a baseball bat, super short stick or long bat thats held at the end? You'd still have 2 hands/ same contact area but more TQ on your side.
CASTRO
Postby lilm » Fri Oct 03, 2008 8:23 am
ahhh that makes perfect sense. Thanks.
lilm
Postby DatSRBoi » Fri Oct 03, 2008 8:31 am
Sorry I have to chime in since it involves supra parts. On a solara I bet it does make a difference....
But man... On a supra its useless in stopping power. First hand experience those stock supra tt size rotors with cap gets hot so fast that we have a hard time stopping EVEN with the slots and drills.
It looks a lot better on a solara.
Postby Akfahad » Fri Oct 03, 2008 10:38 am
wow...looks good!
