SolaraGuy.com • View topic - TRD radiator caps?
TRD radiator caps?
TRD radiator caps?
Postby alltrac92 » Fri Oct 03, 2008 9:09 pm
TRD website list two radiators caps
PTR04-00000-02 21.3 psi
PTR04-00000-01 18.5 psi
Which is the better one to use?
Does anybody know what the stock cap psi rating is?
alltrac92
Postby alltrac92 » Fri Oct 03, 2008 9:13 pm
I checked stant's website and it said a stock replacement cap is 16 psi
alltrac92
Postby TRDSleeper » Fri Oct 03, 2008 9:47 pm
I got the 18.5 psi TRD radiator cap last month. I had trouble deciding which one to get. The stock cap is 1.0 bar=14.5 psi so jumping to 18.5 psi seems reasonable to me. I was worried that the 21.3 psi might be too much pressure and cause some problems as the years go by.
TRDSleeper
Postby Dawgz » Fri Oct 03, 2008 9:52 pm
Im sorry, but i may be mistaken....i thought these TRD Caps were just for aesthetics?
Postby Mr_Chunkz » Fri Oct 03, 2008 11:10 pm
Dawgz wrote:Im sorry, but i may be mistaken....i thought these TRD Caps were just for aesthetics?
supposedly they increase pressure on the coolant which make your car run cooler somehow
screw it i think it looks cool.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby lexmex » Tue Oct 07, 2008 3:08 pm
You won't notice much of a measureable blip unless you also go with a TRD Thermostat. I actually went with a Tom's Radiator Cap.
Technically, what the radiator cap is supposed to do is allow the radiator to cool better by raising the valve opening pressure a bit more.
lexmex
Postby Camry Racing » Tue Oct 07, 2008 8:00 pm
Camry Racing
Users browsing this forum: Google [Bot] and 31 guests
