SolaraGuy.com • View topic - How to remove OEM Radio?
Postby LatinDragonXJC » Sat Oct 04, 2008 7:48 am
I know it's a pretty newb question, but I don't want break something with my Hulk gorilla grip because I pulled on the wrong molding.
Do I have to loosen any screws/bolts?
Do I just yank it from the tape deck?
Any pictures would be great, Thanks.
LatinDragonXJC
Postby Pogs » Sat Oct 04, 2008 8:01 am
Pull the cover ( black peice that goes over the radio/clock/hvac unit.). It will come just pull starting from the bottom then work your way up. The radio has 4 bolts (10mm). Then pull it out and unhook the wires from the back.
Search and Win
Pogs
Postby LatinDragonXJC » Sat Oct 04, 2008 1:52 pm
Pogs wrote:Pull the cover ( black peice that goes over the radio/clock/hvac unit.). It will come just pull starting from the bottom then work your way up. The radio has 4 bolts (10mm). Then pull it out and unhook the wires from the back.
Thanks but I'm looking at it now. By "black piece" cover do you mean the face that has lettering on it. Btw, I have SLE with 6 CD changer, with wood trim. if that makes a difference. Am I detaching what the wood trim is connected to?
Update: disregard the above, the black piece for me was the wood trim, it popped out. Thanks
LatinDragonXJC
Users browsing this forum: Google [Bot] and 31 guests
