SolaraGuy.com • View topic - Replace pulley and adjust belt tension
Postby mlimin » Sat Jun 21, 2003 9:23 pm
Hi guys, I need help on how to replace pulley on the supercharged and how to adjust the belt tension.
Thanks
mlimin
Postby xXsolaraXx » Sat Jun 21, 2003 11:09 pm
try the search function...i remember it being discussed b4...L8r moe
xXsolaraXx
Postby krook » Sun Jun 22, 2003 8:37 pm
if i remember correctly, happy_aggies said you could just simply remove the bolt holding the oem pulley on the S/C, swap the pulleys, and put the bolt back on.
if your S/C kit comes with the belt tensioner already, you don't need to manually adjust the tension.
krook
Postby Yanks0114 » Sun Jun 22, 2003 9:00 pm
you are going to need an pulley puller which can be rented for free at autozone.
Postby happy_aggies » Mon Jun 23, 2003 6:33 am
That is an optional. I did mine w/o it. (I mean Steve did it) :wink:
happy_aggies
Postby mlimin » Mon Jun 23, 2003 7:47 am
so I should just remove the bolt on the pulley and put the new one in?
for the tension, the reason I am asking is because my belt start to slip when I turn on ac. So I am wondering if I can do anything with it. beside that it make some much noise.
mlimin
