SolaraGuy.com • View topic - replacement bushings for TRD RSB
Postby Akfahad » Sat Oct 04, 2008 1:45 pm
Well, found out what my clunking was....my bushings on both sides of the TRD RSB are cracked. Put some WD-40 on there for the time being until I can get some new bushings. BUT...where do you guys know of that I can get some replacement bushings?
Also, anybody know the difference in size between the stock RSB and the TRD RSB. I know the TRD RSB is 3/4" in diameter. (19mm)
Postby ASG14 » Sat Oct 04, 2008 11:01 pm
Drop Dawgz a PM. He may be able to help.
ASG14
Postby Midias » Sat Oct 04, 2008 11:40 pm
Autozone sells universal bushings and holders that fit our cars in red poly. You just need to measure the bar. I think they are about $20 for both.
Postby Dawgz » Sun Oct 05, 2008 6:53 pm
I can get original TRD bushings for the sway bar.
Hit me up if u want it.
Postby Akfahad » Sun Oct 05, 2008 8:08 pm
^^sent
Postby Akfahad » Sun Oct 12, 2008 12:53 pm
FYI...got the new bushing from Mark at Hotchkis Peformance (thanks Ryan). His number 562.907.7757. The part # for the busings is 22793RB, although he did not have them anymore so he sent me another similar kind, #5335G (3/4" bushing). They're the "D" style you need and black in color, but they're little taller than the one's you get with the TRD RSB, so some extra "force" is needed and I ended up using two longer bolts (M8x1.25), one on each side in order for it to fit. Hope this helps others in the future.
Postby dvdchris45 » Sun Oct 12, 2008 12:55 pm
would these bushings apply to the gen 2 rsb as well?
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Akfahad » Sun Oct 12, 2008 3:40 pm
maybe...as long as the diameter of the bar didn't change.
Re: replacement bushings for TRD RSB
Postby corlon » Fri Jul 19, 2013 10:00 pm
ok. so I need to replace my 1999 solara trd rear sway bar bushings. I ordered the 22793rb from hotchkis. went to put them in and they are way too small. they are just a round style bushing, not the bigger d style. here is a picture of the hotchkis bushing in the package next to the trd bushing removed from the vehicle. by the way, the guy at hotchkis said they made the trd sway bars for this vehicle. has anyone had any luck replacing these bushings? were you able to make the 22793rb work somehow?
NiCe
corlon
Postby HARKEM » Sat Jul 20, 2013 9:20 am
You could try the Whitline one to suit there swaybar, tho they don't list them on there website, so you have to find a dealer in your area..
http://www.whiteline.com.au/product_det ... mber=BTR39
it might be the service kit listed: KSK083-20
or quick search on ebay, these suit an 18mm bar and they are cheap and polyeurathane..
http://www.ebay.com.au/itm/Energy-Suspe ... 203&_uhb=1
2001 V6 CAMRY TOURING
DBA 4000 Slotted/Cross Drilled Rotors Front/Rear, EXEDY Stage 1 Race Clutch, FIDANZA 9lbs Flywheel,
Whiteline RSB & FSB, TRD Suspension, CUSTOM Headers&OBX CatBack, TRD S/C:)
HARKEM
Postby corlon » Wed Jul 24, 2013 1:26 pm
nope. the 1st # listed is for a 20mm bar the 2nd is for a 18mm bar. the trd bar is 19mm.
NiCe
corlon
