SolaraGuy.com • View topic - Jim's Fuelmod
Jim's Fuelmod
Jim's Fuelmod
Postby JvR » Thu Oct 09, 2008 5:11 am
Hi you all,
Can some explain this:
http://www.solaraguy.com/viewtopic.php? ... od&start=0
1. Why use an other fuelfilter? (just for the connector?)
I ask this because i want to buy these parts in the Netherlands (europe) where i live. (because shipping cost is very high.....)
2. What is the screw-thread size of the fuelrail
3. Which Walbro pump do i need for 4-6 psi S/C and do i need a fuel regulator?
4. Is there a howto/DIY to make a fuel return line/system incl. fuel presure regulator.
Thanks you all :wnw:
JvR
Postby ASG14 » Thu Oct 09, 2008 8:55 am
1: The thread size of the fuel filter I think is different.
3: Walbro 190 GSS250 for the Gen 4.
ASG14
Postby JvR » Thu Oct 09, 2008 11:23 am
thanks!,
1. so no special stuff, but just a fitment issue ...maybe more capacity and as result more flow.
3. Walbro 190 ...not a 255 and fuel pressure regulator?
Somebody else knows the rest of the answers?
Thanks alot!
JvR
Postby Mr_Chunkz » Fri Oct 10, 2008 9:45 am
JvR wrote:thanks!,
Thanks alot!
3. For 4-6psi 255 is major overkill. Even at 5.5psi with walbro 190 pump, jims fuel mod and 330cc injector I was running dangerously rich. My exhaust smelled like pump gas and my car had trouble starting while it was untuned.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby JvR » Fri Oct 10, 2008 2:26 pm
Thanks, that is information i need.
I think i do jim's fuelmod incl walbro 190 and run on 6psi.....after i install my y-pipe/exhaust.
I think i don't need the bigger fuel injectors??
JvR
Postby ASG14 » Fri Oct 10, 2008 3:21 pm
^ You'll need an SAFC if you run over 4PSI, and then a tune. Don;t forget that!
ASG14
Postby akora12 » Fri Oct 10, 2008 4:21 pm
I believe Jim's fuel filter flows more than the oem unit, but more importantly, it has the correct connections.
The 190 should be sufficient unless you convert to a return-style fuel system. The injectors aren't mandatory, but I'd rather have more than enough capability and tune down rather than overload the injectors.
Postby JvR » Sat Oct 11, 2008 3:47 am
Thanks alot!
This clears up alot .....and i have to safe money for a safc and a tune up :wink: .
So i have to wait for a year to go for the 6psi :cry:
JvR
Postby that1mexguy » Tue Oct 14, 2008 3:20 pm
woohooo, my tutoria is still being looked at!! I rock!!! LOL
that1mexguy
Postby Eye8Pussies » Tue Oct 14, 2008 4:05 pm
Mr_Chunkz wrote:
JvR wrote:thanks!,
Thanks alot!
yeah...that wasn't your pump....that was your injectors doing that...
Users browsing this forum: Google [Bot] and 31 guests
