SolaraGuy.com • View topic - Positive camber with coilovers
Postby thealkimo » Mon Oct 20, 2008 6:38 pm
I just had coilovers installed but my rear wheels now have 1.6 degrees of positive camber even at the full negative setting on the coilover. The shop ordered a camber kit, but that will probably only push it a degree. Any ideas what I can do to solve this problem?
thealkimo
Postby Eye8Pussies » Mon Oct 20, 2008 6:49 pm
so, you're sayiny that you didn't have this problem with your struts and springs?
Postby thealkimo » Mon Oct 20, 2008 7:18 pm
Eye8Pussies wrote:so, you're sayiny that you didn't have this problem with your struts and springs?
with struts/springs i was just a bit negative...
thealkimo
Postby Mr_Chunkz » Mon Oct 20, 2008 7:50 pm
.. go for less aggressive drop?
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby Eye8Pussies » Mon Oct 20, 2008 7:54 pm
^ don't you mean a more aggressive drop? the more aggressive drop, the more negative camber there usually is
see what the camber kit can do first, and then go from there...but I have no idea...hopefully somebody out there would
Re: Positive camber with coilovers
Postby camry_101 » Mon Oct 20, 2008 8:10 pm
thealkimo wrote:I just had coilovers installed but my rear wheels now have 1.6 degrees of positive camber even at the full negative setting on the coilover. The shop ordered a camber kit, but that will probably only push it a degree. Any ideas what I can do to solve this problem?
dam where have you been lol
2007 Ninja 500R stock
camry_101
Postby DaTwUnKrAziEpInOy » Mon Oct 20, 2008 8:12 pm
What c/o do you have ? I have a decent drop with the 225/40/18 +37 offset and don't have positive camber on the rear.
DaTwUnKrAziEpInOy
Postby Toy1mzfe » Mon Oct 20, 2008 8:27 pm
I believe it has something to do with the way u install it.
sometimes when u re-install them, they go in off spec, so ur camber would be off. Typically its positive camber, but majoity of camber/toe/etc is based off installation and such.
Just from the eye, can u see the positive camber? Just hope its not a crappy machine.
Postby CamryOnBronze » Mon Oct 20, 2008 8:53 pm
Ive been stumped as well guys... he bought my old coilovers and I didnt have an issue like this. I ran some positive with them on the stock setting, but when I put them to full negative it was fine. I am really stumped as well, no idea what it could be...
Postby Eye8Pussies » Mon Oct 20, 2008 10:02 pm
hmmm....is the problem the same for both sides?
and I find that really strange as well...do you have damon's old jics, or ksports? with my ksports, I can get both extreme negative camber or extreme positive camber.
Postby thealkimo » Mon Oct 20, 2008 10:20 pm
Eye8Pussies wrote:hmmm....is the problem the same for both sides?
The k-sports...yeah it's weird they measured both sides at +1.6. I left the car at the shop again because it looked like it was going to hit the rear fender over each bump it sticks out so much.
Is it possible to mount the strut incorrectly to the sway bar end links?
thealkimo
Postby Eye8Pussies » Mon Oct 20, 2008 11:16 pm
not really...even if you switch the left and the right hand sides, the pillowmounts should be able to move to the angle needed for the opposite side. then you should only have to deal with the bracket on the strut housing that holds the swaybar link in place...and that can easily be solved by just rotating the housing itself.
That is a very strange situation that you are in....I suppose though, if you have time, to swap the left and the right rears and see if it makes a difference?
Postby thealkimo » Tue Oct 21, 2008 10:16 am
Eye8Pussies wrote:That is a very strange situation that you are in....I suppose though, if you have time, to swap the left and the right rears and see if it makes a difference?
I'm going to have them try this...maybe we'll get lucky!
thealkimo
Postby thealkimo » Wed Oct 22, 2008 10:12 am
The shop didn't have time to swap rear sides, but I guess the camber kit helped a bit. My rear wheels are now +.4 at driver side and +.6 passenger side. The +.4 is hard to tell, but the +.6 is definitely noticeable. I'm going to need another shop to look at this I guess...
thealkimo
Postby ---CAMRAZY--- » Wed Oct 22, 2008 6:41 pm
The holes were the ksprts mount to your hub are slotted... are you sure they tightened them up correctly? Jack the car up, loosen them up, and re-tighten pushing the coilover inward.....
There should be no need of a camber kit.. I had gotten 2.5 degrees of negative camber off the ksports and that was before messing with the mounts.
Good Luck Alex!!
Users browsing this forum: Google [Bot] and 31 guests
