SolaraGuy.com • View topic - Quick question on changing brake pads...
Postby nemoxfishy » Wed Oct 22, 2008 2:02 am
Did any of you guys took off the shims from the stock pads and reuse them?
Or did you just took the whole thing out and just slide in the new pads?
:D :D
nemoxfishy
Postby ThatVietGuy » Wed Oct 22, 2008 2:23 am
I re-used mine.
ThatVietGuy
Postby 5842solara » Wed Oct 22, 2008 2:39 am
i was told stock shims are best.. keep reusing them
5842solara
Postby Chinky420 » Wed Oct 22, 2008 8:49 am
bah
i tossed mine in the spare parts box
no diff in stopage, sound, or durability of pad, in my experience. i always thought they were there to prevent squealing....
plus, depending on what pads you get, they may come with shims integrated into the pad.
Chinky420
Postby Jakecallun20 » Wed Oct 22, 2008 10:11 am
my ceramic pads came with new textured shims, my old ones were toast, since your taking the time to take your brakes apart, go ahead and use the new shims.
Postby (K) » Wed Oct 22, 2008 4:45 pm
The pads I were using had built in shims. At first I re-used the old shims and all was well until I did the other side...the shim was causing the pads to contact the rotor, essentially locking up the brakes. I couldn't get the wheel spinning. Without the old shims I was left with some play. In the end I just tossed the old shims and let the whole thing seat on its own.
(K)
Users browsing this forum: Google [Bot] and 31 guests
