SolaraGuy.com • View topic - need some advice on wheels
Postby Ilovemylara » Thu Oct 23, 2008 6:39 am
hey guys I need some advice... My friend has a set of 17 inch acura wheels.. They are five lug, and Im pretty sure 114.3 so I know they'll fit. They are in decent shape, some chips.. Anyhow I want to know how much I should offer him? what do you guys think?
btw:They have kuhmo tires that have 50% tread wear.
Postby CamryOnBronze » Thu Oct 23, 2008 7:06 am
make sure they fit your car first, then decide what to offer him. Offset is the key, so make sure they fit well and look decent. I would check out some Acura forums to see what they go for, no one here is really going to know for sure. Good luck!
Postby Ilovemylara » Thu Oct 23, 2008 7:15 am
yeah.. I checked around and the offset is 30+mm ..I'm pretty sure I would need spacers right? I have no idea what model they came off of so I couldnt really ask around...
Postby TRDSleeper » Thu Oct 23, 2008 11:12 am
I don't think you would need spacers. I have +40mm wheels that are 7.5 inch wide on my car right now and they come very close to the struts. With +30mm offset, depending on the width of the wheels, you should have good clearance between the wheel and strut. If the wheels are wider than 8inch, then you might need spacers.
TRDSleeper
Postby ThatVietGuy » Thu Oct 23, 2008 1:06 pm
You're gonna have to roll the fender in the back if you're lowered. I tested 350Z wheels (which have +33 offsets) and I rubbed in the rear over any bump.
ThatVietGuy
Users browsing this forum: Google [Bot] and 31 guests
