SolaraGuy.com • View topic - 225/45/18 spacer question
Postby gnaw_divad » Thu Oct 23, 2008 7:47 pm
Just changed my tires today at AMERICAN TIRE COMPANY.
I've always had 225/40/18's and they've cleared perfectly. Slight rubbing in the rear when going over bumps on the strut but never anything serious.
Wanted a slightly smoother ride so I changed to 225/45/18's today, which should fit but they rub on the back strut. I have the C5000 RH Rims - I believe are 18x7.5 +42. Looks like they barely rub.
I've been advised to get a set of H&R Hubcentric Spacers from Tire Rack by the shop but he didn't know what size. He did mention that those were the only spacers he'd recommend.
Anyone with a similar set-up that can advise on a spacer size and company?
Thanks
gnaw_divad
Postby ThatVietGuy » Thu Oct 23, 2008 7:57 pm
I'd say a 5mm spacer is plenty.
You could go H&R or Ichiba.
ThatVietGuy
Postby gnaw_divad » Thu Oct 23, 2008 9:31 pm
THX.. yah, i think it might be safer to go large instead of too small.
gnaw_divad
Postby Mr_Krispy1183 » Thu Oct 23, 2008 9:47 pm
I'm in the market for some 5mms for the rear as well. I'm leaning more towards the Ichibas over the H&Rs, only because I like the idea of the extended thread lugs replacing the stock ones and the spacer sliding onto those, as opposed to the H&R setup, which just bolts onto the existing lugs and uses its own on the spacer to mount the wheel (which is easier overall, but seems like a safety compromise as well). Your choice though, just thought I'd throw my insight out there.
Postby gnaw_divad » Thu Oct 23, 2008 10:47 pm
Awesome, cool to know. I will ask about both when I make the call tomorrow.
What kind of tire set up do you have? I was also wondering if you had any shops that you were planning on making the purchase from?
gnaw_divad
Postby Mr_Krispy1183 » Thu Oct 23, 2008 11:24 pm
I'm running 225/40/18, & my Works are 18x8.0 with a +37 offset. If anything, I had more of a problem rubbing the rear fender than the strut w/my offset this low, but I'm looking to run the spacer to get the wheel to sit more flush with the fender, and give me that much more clearance from the rear struts. Now, to alleviate the front rubbing....(suggestions anyone? Milt?!?)
As far as shops, I'd really just look around for who's got the best price shipped out to you. Evasive Motorsports has a decent rep (sells Ichiba), and there's a set of 5mm Ichibas on eBay for 59 plus shipping right now, listed under Ichiba 5mm Scion xB 08+ (which is the same center bore/bolt pattern-wise as the Solara, 60.1 mm bore, 5x114.3 bolt pattern).
Postby ---CAMRAZY--- » Thu Oct 23, 2008 11:41 pm
So Roll or shave your fender^^^ And LOL at your Low offset...
Mr_Krispy1183 wrote:I'm in the market for some 5mms for the rear as well. I'm leaning more towards the Ichibas over the H&Rs, only because I like the idea of the extended thread lugs replacing the stock ones and the spacer sliding onto those, as opposed to the H&R setup, which just bolts onto the existing lugs and uses its own on the spacer to mount the wheel (which is easier overall, but seems like a safety compromise as well). Your choice though, just thought I'd throw my insight out there.
Wrong, the H&R's are the same way.....
http://www.hrsprings.com/products/trak/
H&R DRS Series spacers fit between the wheel and hub, and require exchanging the existing wheel studs for longer ones.
DRM Series spacers bolt to the hub with existing wheel studs and special nuts (included). Wheel is bolted to new DRM wheel studs.
Now Ichiba
Version I
http://www.ichibausa.com/whspad.html
Version II
http://www.ichibausa.com/whspveii.html
I have used both from both before... and all is good in the hood...
Postby Mr_Krispy1183 » Thu Oct 23, 2008 11:51 pm
^Thanks for the clarification/advice bro, I wasn't aware that H&R did both types as well.
And haha, yeah yeah, I meant low for a FWD Camry w/no fender/liner modifications, since I don't see anyone besides Richard go any lower than +40-42; you RWD, near negative offset guys don't count!
Postby gnaw_divad » Fri Oct 24, 2008 8:22 am
thanks for the info!
I was just checking both the websites and for H&R they say their spacers vary from 10-40mm and Ichiba for the Solara has the smallest spacer at 15mm... ?? Do they not make a 5mm spacer or does it just have to be custom ordered.
gnaw_divad
Postby Mr_Krispy1183 » Fri Oct 24, 2008 8:31 am
Icihiba makes 5mm, it's H&R that doesn't make one less than 10mm, at least from what I can see.
Postby ---CAMRAZY--- » Fri Oct 24, 2008 8:37 am
H&R and Ichiba both make 5mm spacers.
H&R does not make 10mm for some reason (for our applications).....
Postby Mr_Krispy1183 » Fri Oct 24, 2008 8:52 am
^Cool, found the 5mm H&Rs. Now I just need to find the right price, and someone local to bang out my old studs (no homo)
Postby Toy1mzfe » Fri Oct 24, 2008 10:38 am
^^^ fyi i would be on club lexus wheel section and look for their used spacers. Thats where i got my many spacers back then.
Postby gnaw_divad » Fri Oct 24, 2008 12:22 pm
Hey, just called H&R directly. They said the only 5MM spacer they carry for the 2000 Toyota Solara is the DRF part #10656014. This is the set where you will have to have your studs pressed to get installed.
I got a quote for $58.95 plus $15.00 shipping for the pair from one of the dealers that was listed on their site. Foreign Auto Tech. Ordered and should receive in 2 - 3 days.
Hope these work out!
gnaw_divad
Postby lightear » Fri Oct 24, 2008 1:08 pm
---CAMRAZY--- wrote:H&R and Ichiba both make 5mm spacers.
ARE YOU SERIOUS? Then what am I sending to you? Thought these were H&R 10mm spacers.
lightear
Users browsing this forum: No registered users and 76 guests
