SolaraGuy.com • View topic - hid problem
hid problem
hid problem
Postby 5842solara » Fri Oct 31, 2008 11:59 pm
hey, i just got hid hi/low.
when i go to high beam. the light does not turn on. its as if i turned off my lights.
i know the bulb works because i probed it and it went on.
do i have to rewire something?
\thanks
5842solara
Postby ThatVietGuy » Sat Nov 01, 2008 12:40 am
You may have the plugs switch around. I don't know what kit you have, but if you can switch the connections around then try that.
ThatVietGuy
Postby 5842solara » Sat Nov 01, 2008 2:00 am
its plug and play. and only one plug. its the hid kits where the high beam is like a stock bulb.
there are 2 bulbs ... side by side..
5842solara
Postby mazen222 » Sun Nov 02, 2008 4:27 pm
there is a connection that goes into the ballast, make sure it is correctly inserted... try to take it out, twist 180 degrees and put it back in. I remember having a similar problem and that was my mistake.
1999, 5 Speed V6
mazen222
Postby 5842solara » Mon Nov 03, 2008 2:29 am
hmm well i will try, but the low beams seem to work fine. so im guessing thats not the problem...
5842solara
Postby 5842solara » Mon Nov 03, 2008 3:57 pm
haha. i forgot that i pulled out the fuse because i had to for school and i forgot to put it back.. now it works.
thanks though for all the replys
5842solara
