SolaraGuy.com • View topic - Noise of TRD swaybar vs. Stock
Postby Solorange » Sat Nov 08, 2008 10:49 am
Just curious as to why I have to keep greasing my swaybar about every 6 months to stop it from creaking vs. not having to grease my stock swaybar at all when I had that on? This is starting to get old lol
Postby Somedude » Sat Nov 08, 2008 10:56 am
What kind of grease you using on the sway bar?
KY jelly? :lol:
Somedude
Postby Mr_Krispy1183 » Sat Nov 08, 2008 11:17 am
If possible, I would definitely take it off, apply Teflon tape, and use marine grease on it as well. Hopefully that should cut down on your re-greasing frequency.
Postby SleeperSolara » Sat Nov 08, 2008 12:33 pm
It's cause OEM uses rubber, and the one for the TRD RSB is poly.
You can wrap your RSB wit teflon tape, and then use White Lithium grease.
Postby kwyse » Sat Nov 08, 2008 12:35 pm
I put a layer of grease around the bar, then teflon taped around that, and then re-greased around the tape...I haven't heard any squeaking in over a year.
kwyse
Postby Somedude » Sat Nov 08, 2008 1:40 pm
The lube that came with the bar don't last long, after two years of hearing that squeaking noise, I relubed the bar (about two years ago) with a can of grease made by mobil (it is red in color) and it hasn't squeaked till this day.
If you use a good grease you don't have to relube that often.
Edit: here is a picture of the can of lube that I used last time to relube the rear sway bar on my car:
Somedude
Postby Midias » Sat Nov 08, 2008 2:29 pm
Teflon paste don't even need to do any taping. Or white lithium grease.
Postby Solorange » Sat Nov 08, 2008 7:49 pm
Ive used, lithium grease, silicon grease, and even some industrial machine grease from work and all three have resorted back to creaking. I guess I will try the teflon tape. Im actually afraid of taking the thing off now because last time I did that I broke the bolts because they rusted through on the other side. I had to buy an all new bracket because I couldn't drill and tape it out. You can see how this has become a pain in my a$$ lately.
Postby corlon » Sat Nov 08, 2008 8:44 pm
just wondering, what part are you guys talking about putting grease on? the whole thing?
NiCe
corlon
Postby Somedude » Sat Nov 08, 2008 8:46 pm
^^Only on the part of the swaybar where it touches the Bushings.
Somedude
Postby Midias » Sat Nov 08, 2008 8:56 pm
For more than a year now I have had luck with teflon paste from the plumbing section of the hardware store no squeak and no tape to mess with.
Read this
http://www.solaraguy.com/viewtopic.php? ... t=hate+trd
Postby No Power » Tue Nov 18, 2008 7:35 pm
Would you be intrested in selling it? :lol:
No Power
