SolaraGuy.com • View topic - safc II not functioning properly... PO 100?
Postby hskrsolara » Mon Nov 10, 2008 5:31 pm
Hey guys,
So, I went to start up the solara and had some problems. First, the safc II screen lights up the whole screen, essentially showing a blank screen. I can't control anything on the safc. 2nd...idle is VERY rough, cant really drive it anywhere as it dies as soon as I get out of the throttle. Then, I pull a PO 100 (MAF) code. Any idea whats going on? I called my tuner and he said he's never seen it before. Maybe a bad ground on the safc wiring? I remember Akfahad having some similar issues before, but not sure what the problem ended up being.
hskrsolara
Re: safc II not functioning properly... PO 100?
Postby Dawgz » Mon Nov 10, 2008 5:59 pm
hskrsolara wrote:Hey guys,
1) check all the wiring for the safcII
2) the safcII might have taken a crap...did u buy it new?
Postby hskrsolara » Mon Nov 10, 2008 6:11 pm
i bought it used...but it has worked fine for a long time.
I am going to check all the connections and open up the safc II to check the internals.
hskrsolara
Postby Akfahad » Mon Nov 10, 2008 6:36 pm
yep....check all the connections to the ECU and take the car for a run, it the problems persist, try disconnecting the MAF wire that goes to the safc, leaving the origional connection. If the car runs great, the safc needs to be replaced. don't know why, i've never heard of it either and neither did my tuner, but it is a piece of hardware so.....
Let us know.
Postby hskrsolara » Mon Nov 10, 2008 6:49 pm
can I just disconnect the safc completely, til I get the problem figured out? will this affect anything?
I checked all the wiring and nothing was loose. opened up the case and nothing was loose. Maybe the unit went bad. What ever happened to yours Akfahad? Did the safc fail?
Is the Neo wired any differently than the safc II? Not sure if I want to replace this one with another safcII, since the knock readout really isn't functional anyways. But I have a black case that meshes well with my interior...decisions.
hskrsolara
Postby hskrsolara » Mon Nov 10, 2008 7:45 pm
http://www.dsmtuners.com/forums/newbie- ... fc-ii.html
looks like it has happened before...must be a dead unit. anyone know where to get a safcII?
hskrsolara
Postby Dawgz » Mon Nov 10, 2008 8:11 pm
hskrsolara wrote:http://www.dsmtuners.com/forums/newbie-forum/251355-anyone-familiar-safc-ii.html
ebay?
Postby hskrsolara » Mon Nov 10, 2008 8:44 pm
^^first place i checked...but I'd like to get a new one.
hskrsolara
Postby Midias » Thu Nov 13, 2008 7:17 am
ebay brand new they seem to be rare a neo might be your best bet.
http://cgi.ebay.com/ebaymotors/Apexi-SA ... ccessories
Postby Dawgz » Thu Nov 13, 2008 8:10 am
^ thats how much i paid for mine new....not bad
Postby Akfahad » Sun Nov 16, 2008 2:51 pm
hskrsolara wrote:can I just disconnect the safc completely, til I get the problem figured out? will this affect anything?
sorry it's been a while....yes, it was a bad unit and replaced with a brand new neo from ebay. wiring is pretty much identical, except the neo has two volt wires instead of one...
