SolaraGuy.com • View topic - headers
headers
headers
Postby solara90 » Fri Nov 28, 2008 6:08 pm
would this work http://www.advancedjdmparts.com/product ... 482&page=1
i know its for the scion tc but it has the same motor
02 solara 2az
solara90
Postby Jakecallun20 » Fri Nov 28, 2008 10:51 pm
It will bolt on to the 2AZ fine, and I see o2 sensor bungs. So your good there, but don't be surprised if you run in to problems fitting the test pipe around the bars/arms under the motor, as they are different in the Solara.
Postby gnegroni » Sat Nov 29, 2008 11:58 am
Jakecallun20 wrote:It will bolt on to the 2AZ fine, and I see o2 sensor bungs. So your good there, but don't be surprised if you run in to problems fitting the test pipe around the bars/arms under the motor, as they are different in the Solara.
A few people here... I think 47th ronin, had some scion tC headers installed. Like Jake said, bolt up to engine fine but will need yo have some work done below.
gnegroni
Postby solara90 » Sat Nov 29, 2008 10:22 pm
so if i just install headers with out the down pipe will it bolt up to the stock down pipe
02 solara 2az
solara90
