SolaraGuy.com • View topic - Camry speed meter gear
Postby hksboost » Tue Dec 30, 2008 11:09 am
My camry speed meter gear does not fit in to the Kaaz LSD because it is approximately 3mm larger than it should be to fit in to the Kaaz LSD.
This is the speed meter gear:
Please help me to solve this matter
TurboNetics T-60
471 Whp / 467 lbft @ 20 psi
hksboost
lsd parts
Postby trd4life » Tue Dec 30, 2008 11:47 am
You need the mr2 turbo one.
Postby hksboost » Tue Dec 30, 2008 12:24 pm
If i don't use the speed meter gear any problem will hapen or not?
TurboNetics T-60
hksboost
Postby gnegroni » Tue Dec 30, 2008 1:46 pm
hksboost wrote:If i don't use the speed meter gear any problem will hapen or not?
Does the odometer run without that gear? If not, then only a few more tickets than usual I guess...
gnegroni
Postby hksboost » Tue Dec 30, 2008 9:45 pm
I don't think the odometer will run
No problem for more tickets but I am afraid for other things that will effect the performance of the car
TurboNetics T-60
hksboost
Postby trd4life » Wed Dec 31, 2008 11:16 am
When installing a Kaaz LSd into a Camry E153 trans, there are a few OEM parts from the mr2 trans that need to be swapped in for the LSD to work 100%.
Do a search on here for a user named SCV6 he went through this same situation your going through he will have the answer you need for sure.
