SolaraGuy.com • View topic - How to replace fog lamp on 1999 Solara SLE V6
Postby Pearl White » Fri Jan 02, 2009 12:51 pm
The right side fog lamp is not coming on, I suspect a burned out bulb or bad socket connection. Dealer wanted $41 to fix, when bulb was only $10.
What is the best way to replace the bulb? Can you access from engine compartment? Or under and behind the bumper there is a metal panel held on by 4-5 screws. Do I unbolt this panel and reach in? How about the bulb number I need ? Thanks!
1999 Solara SLE V6
Pearl White
95,000 miles
Pearl White
Postby akora12 » Fri Jan 02, 2009 1:22 pm
Bulb is 9006. Just undo a few of the screws that hold the plastic liner to the bumper and you should be able to reach the bulb.
Postby nemoxfishy » Fri Jan 02, 2009 5:41 pm
Access it from under the car, just in front of the front wheel.
It's a piece of cake, 15 min then you're done!
nemoxfishy
Postby Pearl White » Fri Jan 02, 2009 6:30 pm
Thanks for the quick replies akora12 and nemoxfishy-my weekend projectjavascript:emoticon(':D')
Pearl White
