SolaraGuy.com • View topic - TRD EBC????
TRD EBC????
TRD EBC????
Postby NRDriver » Fri Jan 16, 2009 9:41 am
does anyone know what the toyota ebc for the supercharger kit does? i have one in my car from the previous owner and am wondering if its something i would want to use on my turbo setup
NRDriver
Postby KILLA CAM » Fri Jan 16, 2009 9:53 am
It's been a long time since I've seen this discussed, but I'm pretty sure it cuts boost when shifting, and I know it was debated, but some thought it did not boost in 1st gear for the auto EBC. I'm sure one of the OG's will give you a better answer...
-Killa
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby akora12 » Fri Jan 16, 2009 11:04 am
I don't think it would work, but I'm no turbo expert either. If you're manual, I would assume a typical boost controller would be more effective since we don't really need the EBC anyways.
Postby lilm » Fri Jan 16, 2009 2:59 pm
for autos there is no boost in first and in between shifintg and in a 5 spd there is no boost in first....
lilm
Postby STYLSH » Sat Jan 17, 2009 8:41 pm
Also cuts boost a couple hundred rpms before fuel cut.
STYLSH
Postby no_escape » Sat Jan 17, 2009 10:31 pm
KILLA CAM wrote:It's been a long time since I've seen this discussed, but I'm pretty sure it cuts boost when shifting...
-Killa
Wouldn't a BOV take care of that for a turbo setup? I would assume you wouldn't need an EBC if you have a BOV.
no_escape
Postby JvR » Sun Jan 18, 2009 5:42 am
Hi, if I'm right ....you ask: can i use (do i need) the EBC for a turbocharged setup.
Answer is ....NO!
The EBC only works with the S/C. It controls the valve of the S/C (blue circle):
(sorry about the mess... i will clean it up this year :lol: )
But if you can use the signal to control a boost valve maybe you can use it.
So the risk,without EBC is, that you kill your gear-box...but with a turbo setup i think you have to change/replace it one day anyway.
JvR
stuff
Postby NRDriver » Sun Jan 18, 2009 7:55 pm
thanks alot. i think that answers it for me
NRDriver
Postby gnegroni » Sun Jan 18, 2009 8:33 pm
lilm wrote:for autos there is no boost in first and in between shifintg and in a 5 spd there is no boost in first....
Wow, that sucks! Absolutely no boost in 1st gear. I think Toyota was scared? Why not use something ALA Mazdaspeed3 where full boost will only be seen from 3rd gear on, but partial boost is available in 1st and 2nd?
gnegroni
