SolaraGuy.com • View topic - 19's - Why Do Some Have Problems and Others Fit?
Postby Guest » Tue Jul 01, 2003 10:23 pm
I've got a 99 SEV6 Stick and am looking at getting the Zenetti Mystik 19x8.5's - I've seen many different forums and comments and some Solara owners have 19x8.5's that fit without rubbing and others have to shave or roll the fenders. I'm not sure what the offset on these particular rims are and would like to know if anyone else does.
Is the offset on a 19x8.5 all that's going to make the difference between rubbing and not?
If it helps, I'll most likely put the Toyo Proxes TS-1's 235/35/19's. (any opinon on 19" tires is greatly appreciated - I know I'm definitely going to sacrifice some of the comfort of riding in the "Baby Lex", but still, some tires do ride smoother than others)
Thanks....
Guest
Postby mlimin » Tue Jul 01, 2003 10:38 pm
it's all depend on the offset. for me, I have racing cr 19X8.5, and I have different offset between front and rear. I think I have 35 and 38 offset.
The shop is the one that figure out the offset.
mlimin
Postby ICrazyChrisI » Wed Jul 02, 2003 12:34 am
I have 19x7.5. No problems here. Im unsure about the offset though.
ICrazyChrisI
Postby chef solara » Wed Jul 02, 2003 4:15 am
I think that I have a 44 offset all around, w/ no problem at all.
chef solara
Postby chef solara » Wed Jul 02, 2003 4:17 am
chef solara
Postby happy_aggies » Wed Jul 02, 2003 6:29 am
Mine is 19x8 w/ 38 offset, I rolled my rear fender and no rubbing at all even w/ 3 guys at the back. :D
happy_aggies
Postby STR8PYP » Wed Jul 02, 2003 7:17 am
It's all about the offset. With the proper offset you'll have no rubbing issues. Nominal for a 19x8.5 I believe is +38 and +45.
Also, different tires will have different widths, yes, even when they're spec'd at 235. Yokohama AVS Sports are true 235mm wide, while Pirelli P7000s for example will be 231-232mm wide. When you go this size, those few mm's can make a difference.
SC
STR8PYP
