SolaraGuy.com • View topic - Injen Intake and Smog Test
Postby mightymouse402 » Tue Feb 03, 2009 12:48 am
Hello all,
I was just wondering if those of you with the Injen IS2030P Intake for the Gen 1 V6 had any trouble passing Smog test. Did you guys have to switch back to the stock air box when you took it to the smog testing place or was everything fine when you tested?
Thanks!
Any responses are appreciated. :)
That's what she said...
mightymouse402
Postby ThatVietGuy » Tue Feb 03, 2009 12:53 am
No. I passed with an Injen and JIC exhaust.
You should be fine.
ThatVietGuy
Postby Mr_Krispy1183 » Tue Feb 03, 2009 1:26 am
^Correct. I as well have an Injen (w/UPFD extension), and the test operator didn't bat an eye. As long as you have Injen's CARB E.O. badge in place on the pipe, you'll be fine.
Postby Toy1mzfe » Tue Feb 03, 2009 1:44 am
No problem at all.
Also with injen and custom catback.
u'll be fine. CARB legal FTW
Postby Mole » Tue Feb 03, 2009 9:33 am
as long as you have the stock cat, you're gold. i passed with 5.5 pulley and 295 injectors...
as long as the smog place doesnt care about intakes (visual,) you're fine.
